In two weeks, we'll hold a competition. The goal of the competition is to get the plane as far as posible (in a straight line).
I have some questions about aerodynamics though...
- The plane needs to fly as far as possible. Which type of plane should I contstuct to obtain this goal? Do I need a fast plane, or a slower "sailor"? The plane doesn't have any controls, and is launched by hand.
To make my further questions a bit more clear, I made some illustrations;
Here you have a front view of the wings. Which one is the best? As the plane doesn't have any controls, it's VERY important to maintain a straight course here. If the wings are built in a V-shape, it'll be more stable. What's the best combination? 1, 2 or 3? Or something else?
Winglets. Do I need them? Are they efficient if used on such a small scale (wing span ca 70cm)? And if I use them, would it be better if they bended downwards too?
The wings again. Is it better to use a wing which is swept a bit backwards, or a straight one? Do I need a long & small wing, or a more delta-shaped one?
The vertical tail fin & winglets. What's the profile of the vertical tail fin? Is it shaped like a droplet to have less resistance? Or is it better to have more resistance (to maintain course)?.
The tail. Do the horizontal tailfins need to be angled? Or is it better to build a V-tail? Which one will best maintain a perfect straight course? Personally I think nr 1.
I know airliners fly with a small nose-up attitude. What's the exact advantage of this? Do I need to construct my plane to fly with the nose up a bit too?
The wing profile. Is a hollow "bird" wing better? A "clean" & fast wing, or a slower wing, like if the flaps were extended?
I know it are a bunch of questions, but it would be great if someone could shed a light on this
Thanks,
Tuur
