KLM 737 ran of the runway
AN124
Post by AN124 »
Just read a article on the dutch teletekst that a KLM 737 ran of the runway after landing at Barcelona.
The landinggear is reported to be heavely damaged.
source: http://teletekst.nos.nl
Best Regards,
Yvo
liebensd
Post by liebensd »
Yvo,
I can't view your link. But here is an other link for the persons with the same problem.
Dave
LX-LGX
Post by LX-LGX »
B737-400, according to www.schiphol.nl
Luckily everyone is alright, thanks for reporting An124! Just made a small article: https://www.aviation24.be/article6642.html
Plane is Boeing 737-400 PH-BTC
NOTAM:
Valid from 28 Nov 2004 to 28 Nov 2004 (released 28 Nov 2004 at 19:11:03)
SUBJECT: HIGH DELAY
OPERATORS AND ATC UNITS ARE ADVISED THAT THERE ARE MAJOR DELAYS
IN THE FOLLOWING AREAS: ARRIVALS AND DEPARTURES LEBL
DELAYS ARE CAUSED BY INCIDENT (DISABLED AIRCRAFT)
ARR AND DEP AVERAGING UP TO 120 MINUTES
SN30952
KLM off runway @ Aeroport del Prat de Llobregat
Post by SN30952 »
liebensd wrote:I can't view your link. But here is an other link for the persons with the same problem. Greetz, Dave
For the many under us who speak Catalan here is the news from Catalan TV:
Un avió causa un ensurt a l'aeroport del Prat en sortir de la pista quan hi ha aterrat
Probably the KLM captain missed because he couldn't pronounce the name of that airport.... El Prat de Llobregat, El Prat International Airport, aka El Prat is the second largest airport of Spain. The airport IATA Airport Code is BCN.
2 Runways, both with aircraft size max: B747:
Runway 1: Heading 07/25, 3,353m
Runway 2: Heading 02/20, 2,720m
And before you ask me, here is the weather at that time:
Temperature: 14.0 °C
Dew Point :11.0 °C
Humidity :82%
Pressure :1018 hPa
Visibility :10.0 kilometers
Wind Direction :SW
Wind Speed : about 13.0 km/h
Gust Speed :N/A
Precipitation :N/A
Events :N/A
Conditions: Mostly Cloudy
This GEN indicates that it would be probably a mechanical failure (and not a pronunciation error :wink: LLLLlobregat...)
And nobody got hurt.
janhuub
Post by janhuub »
It has 3 runways now, 07R/25L and 07L/25R and 02/20. Just like Brussels
Jan
SN30952
You may repeat that to zoom in more.
Post by SN30952 »
janhuub wrote:It has 3 runways now, 07R/25L and 07L/25R and 02/20. Just like Brussels Jan
This is the source I based my info on Jan.
It is a long time, I did go that way. Please check it by this In this link goto: Planos de aeropuertos and select Barcelona
Have also a look at this: BCN / LEBL and also this link El Prat
When you click 2X in, you zoom in on the airport, and what do we see? You may repeat that to zoom in more.
janhuub
Post by janhuub »
Didn't know about it either. A lot of construction work going on over there.
Landed on the 07R last Thursday.
Normally you shoudl find all info here: http://ais.aena.es/ but can't open it right now, it's going very slow.
Jan
LX-LGX
Post by LX-LGX »
Does someone know for sure what happened ?
Did he land on a wrong place on the runway, was there a brake problem, miscalculation, wrong runway, ?
SN30952
La nueva rwy 25L
Post by SN30952 »
janhuub wrote:Didn't know about it either. A lot of construction work going on over there.
Landed on the 07R last Thursday.Jan
That is Runway 1, Jan?
In 1998, the airport was voted Europe’s best.
The airport had 21 million passengers passing through in 2002, compared with just ten million in 1992, the year of the Barcelona Olympics.
The airport consists of three terminals, A for international departures and arrivals, B for national and some EC flights, and C for the Puente Aereo or shuttle flights to and from Madrid and other major Spanish cities.
And I read this:
A third runway and a new offloading area have been planned for 2006, to cater for the increasing volume of air traffic.
Have they been quick?
Notice BCN had been and still is trouble free since 1970, July 3, when a british charter Dan-Air Comet jet crashed into the sea while coming in for a landing at Barcelona; 112 dead. Nothing to do with BCN Airport, actually...
For the amigos, who speake the Spanish: Lima Ecoon Nueva pista LEBL Its starts in BCN in Spanish, but later in English....
We had a tread on that some weeks ago.
KLM 737 SIM @ BCN
sab319
Location: Mortsel, antwerp, Flanders, Belgium, Europe, Earth, Milky way
Post by sab319 »
Well didn't the same thing happen to a transavia 737 in EHAM a couple of years ago?
Bottie
Post by Bottie »
AN124
Post by AN124 »
Whooeps looks like that once is seriously damaged.
When looking to the picture I would see the landinggear collapsed.
Best Regards,
Yvo
AN124
Post by AN124 »
At the following link you will find a closer shot of the 737:
http://www.planepictures.net/netshow.php?id=281902
Best Regards,
Yvo
clr0901
Passenger experience
Post by clr0901 »
I met someone today who was on that flight. Apparently the aircraft landed normally but shortly after touchdown, there was a report and the aircraft began to swing one way and the other, eventually running off the runway into the sandtrap. Undercarriage was buried in the sand. He was able to walk off the wing onto the ground from the overwing exit. Could have been a lot worse as there's a deep drainage gully a few metres away - fotunately plane stopped short of that.
No injuries.
SN30952
Re: Passenger experience
Post by SN30952 »
clr0901 wrote:...Apparently the aircraft landed normally but shortly after touchdown, there was a report and the aircraft began to swing one way and the other, eventually running off the runway into the sandtrap. Undercarriage was buried in the sand. No injuries.
A mechanical failure: brake problem? As I tried earlier Sunday, see higher: This GEN indicates that it would be probably a mechanical failure.
Things that can happen, as bird strike is also a hazard.
In these cases, one wishes (s)he is in the hands of a well trained crew.
sab319
Post by sab319 »
KLM the 'reliable' airline :mrgreen:
LX-LGX
Post by LX-LGX »
nwa757
Post by nwa757 »
Do you think this plane will be saved or will it be broken-up for parts?
Onward and Upward...
C_J
Post by C_J »
that would never happen to SN Brussels Airlines...
