Anomalies in BRU-ANR-CRL-LGG-OST in 2021
Re: Anomalies in BRU-ANR-CRL-LGG-OST in 2021
Today's Austrian OS-352 Brussels-Vienna diverted to Nuremberg.
Reason: cracked windshield.
http://avherald.com/h?article=4e1d957c&opt=0
Samuel Zerilli
Post by Samuel Zerilli »
This airbus A320 was apparently diverted to Orly, no emergency declared nothing but still planned on the airport site so is not a fr24 bug.
Édit : The plane stops at Paris Orly before coming to Brussels. Satus modify on the Brussels Airport website
@ANR Cessna 525 9A-JSC overran rwy11 ending up in the RESA area, taking down some app. lights in the process.
pitrixplanespotting
Post by pitrixplanespotting »
DIBO wrote: 30 Jan 2021, 21:05 @ANR Cessna 525 9A-JSC overran rwy11 ending up in the RESA area, taking down some app. lights in the process.
at the end of the runway going 41 kt
If FR24 is 100% accurate, touchdown was late:
https://www.flightradar24.com/data/airc ... c#26b44fe2
@ANR: last incoming flight of the day SF34 PH-CUA diverted in the meantime to Maastricht Aachen Airport.
TangoLima posted the tweet with pictures in the Plane Spotting forum:
On board was Belgian footballer Dries Mertens, who plays for SS Napoli.
https://www.nieuwsblad.be/cnt/dmf20210203_92321966 (NL)
https://www.lesoir.be/352840/article/20 ... terrissage (FR)
There was a partial power failure at AMS Amsterdam this morning, causing 'no runway lights'. Hence this divertion to LGG Liège: AirBridgeCargo 747-8F VQ-BRJ:
https://www.flightradar24.com/data/airc ... j#26c3f3c4
And at this very moment, a lot of incoming flights into AMS are going into a holding because of the weather/snow. So BRU may expect some more visitors.
https://www.flightradar24.com/52.26,4.17/8
VQBRJ left LGG for AMS but has little chance to land there it seems. Odd. Optimistic people...
Acid-drop wrote: 07 Feb 2021, 08:47 VQBRJ left LGG for AMS but has little chance to land there it seems. Odd. Optimistic people...
Returning to LGG at the time of writing. Some others flights also diverting from AMS, mostly to CDG/DUS/FRA. So far none for BRU.
EHAM 070825Z 06029G41KT 1200 R18C/1600N R27/1200D R18R/////N R06/1400N -SN DRSN FEW005 BKN006 BKN015 M03/M06 Q1001 R99/4///91
TEMPO 2000 BKN012
Dry snow on the runway, braking action poor.
ZavCity
Post by ZavCity »
At this moment landings on rwy 06 AMS ..Seems no diversions to BRU!
gtz
paul
sdbelgium wrote: 07 Feb 2021, 09:45
TEMPO 2000 BKN012
And to make it worse for Amsterdam: 06-24 (Kaagbaan) is the only runway in use for take offs and landings. And then this just happened: "...snow clearing vehicle is stuck at Runway 06, fire brigade is needed to free him..."
Normal operations at CRL, EIN diversions to CGN...
And might be the only time in BRU history, but they are using 25R for landings and 07L for takeoffs at the same time, but they are able to do it thanks to the low traffic.
Air Nostrum CRJ-1000 EC-MQQ broke off the final approach for 25R @BRU and entered the ANT (Antwerp VOR) holding to run some checks.
Edit: nothing the QRH couldn't fix, back on the ground some 10 minutes later.
Avherald reporting a ‘brakes problem’ and recomputation. http://avherald.com/h?article=4e2d8ac7&opt=0
Longtail B744 VQ-BWT seems to have had some kind of engine problem after departure from Maastricht this afternoon around 1600. Media reports that the aircraft lost some metal parts that landed on top of cars in the vicinity of the airport. The aircraft entered a holding pattern and diverted to Liège, where it landed at 1715LT.
https://www.flightradar24.com/data/flig ... 4#26debe99
https://www.nu.nl/binnenland/6117601/vl ... adigd.html (Dutch)
SR20
Post by SR20 »
sdbelgium wrote: 20 Feb 2021, 17:18 Longtail B744 VQ-BWT seems to have had some kind of engine problem after departure from Maastricht this afternoon around 1600. Media reports that the aircraft lost some metal parts that landed on top of cars in the vicinity of the airport. The aircraft entered a holding pattern and diverted to Liège, where it landed at 1715LT.
https://simpleflying.com/boeing-747-eng ... gine-fire/
Wow, this is quite serious
Could have been worse for people on the ground
http://avherald.com/h?article=4e35302b&opt=0
There was big flock of cranes between liege and maastricht today mid afternoon, could be a good explanation
It was already noticed 3 days ago
https://www.rtbf.be/info/societe/detail ... d=10700451
