Contrail spotting August 2018.
This space is now open for your hot contrail pictures of August 2018.
Re: Contrail spotting August 2018.
Cześć,
01.08
BHAir, BGH4019, BOJ-BLL, LZ-BGH, A320, KENIN-BINKA, G16:49
02.08
United, UAL954, SFO-TLV, N2534U, B77W, FL350, BABEN-DENKO-LENOV, G17:32
PS. Where are you contrails spotters?
01.08
02.08
Air Belgium Airbus A340-300 OO-ABA at 16,350 feet above Antwerp. Picture by "Canon Paul".
New to this, using Samsung S7 with skymax 102.
A few pictures which i took early a.m. on the 11/08...
A lot of haze around..
More later
A330A340
More later
Bridge camera or telescope?
1200mm telescope.
All the best
Follow on from my post above,
a330a340
They are stunning, when you say 1200mm scope I presume you have a dob? Have you attached a DSLR to this?
HiHollins185 wrote: ↑14 Aug 2018, 12:00 They are stunning, when you say 1200mm scope I presume you have a dob? Have you attached a DSLR to this?
Please find the following links which will help you.
http://www.skystef.be/scope-setup.htm
http://www.skystef.be/contrail.htm
I take most of my pictures just after SUN up when their is less HEAT HAZE at this time of year.
Hope this helps.
Follow on from my posts above
a330a340
Follow on from my posts above,
Thats it for now untill next time.....
a330a340
Air bridge cargo 32,000ft routing to Amsterdam. Taken with galaxy S7 on a mak102,no post processing.
Cześć,
21.08
AirCanada, ACA84, YYZ-TLV, C-FGDX, B789, FL370, KEKOV-KEKED, G6:22
22.08
SmallPlanet, LLC1033, OUL-SPU, LY-SPF, A320, FL360, BOKSU-ABEXA-SUPAK, G17:27
Alitalia, AZA785, NRT-FCO, EI-ISE, B772, FL380, L856 SW, G17:33
WizzAir, WZZ6AM/1442, FCO-WAW, HA-LXN, A321, FL370, GEMBA-WAW, G17:36
21.08
22.08
A few more pictures which i took early a.m on the 26/08.
Had a lot of haze which made it hard to keep them sharp.
Nice pictures vader
a330a340
Nice pictures vader
