BRU 09/06/2018
Forum rules
viewtopic.php?f=21&t=12716
BRU 09/06/2018
sta 13:30 B73M TF-ICE ICE554 from BIKF
std 14:15 B73M TF-ICE ICE555 to BIKF
std 15:35 A342 A7-HHK to OTBD
std 16:15 B739 9K-GCC KUG079 to OKBK
Re: BRU 09/06/2018
xxxx-1515 GLF6 VPCER
1540-xxxx C56X DCAHO
xxxx-1555 A342 A7HHK
1615-1745 LJ55 DCWAY
xxxx-1640 KUG B739 9KGCC
1815-xxxx CL60 DANTR
ALL TIMES LOCAL
ALL TIMES LOCAL
Re: BRU 09/06/2018
1600-1650 AEH E145 FHRAM
ALL TIMES LOCAL
ALL TIMES LOCAL
- Established02
Re: BRU 09/06/2018
LH543 BOG-FRA A343 diverted to BRU just now. This happened also a few months ago with exactly the same flight.
Re: BRU 09/06/2018
Interestingly, two days ago (June 6), LH543 diverted to Koln.
Re: BRU 09/06/2018
.Established02 wrote: 09 Jun 2018, 15:01 LH543 BOG-FRA A343 diverted to BRU just now. This happened also a few months ago with exactly the same flight.
Fuel stop.
Quentin Glodé
Re: BRU 09/06/2018
25 March 2018 with D-AIGSEstablished02 wrote: 09 Jun 2018, 15:01 LH543 BOG-FRA A343 diverted to BRU just now. This happened also a few months ago with exactly the same flight.
Re: BRU 09/06/2018
It has spent exactly two hours in BRU. That's a long fuel stop! What a waste.
It's interesting to notice that a fuel stop may be required for a flight that usually doesn't exceed 11 hours. It's normally well within the A340's capabilities but Bogota airport must be really challenging.
Re: BRU 09/06/2018
Request about the Lufthansa Technik hangar : What is the reg. of the LEVEL A330 inside the hangar
and what is the ID of that all white A330 in front of it?
Arnoud
Arnoud
Re: BRU 09/06/2018
The LEVEL A330 is F-HLVL, the all white A330 I don't know. But this is probably a Hi Fly Malta plane.zerosix24 wrote: 12 Jun 2018, 10:55 Request about the Lufthansa Technik hangar : What is the reg. of the LEVEL A330 inside the hangar
Arnoud
Re: BRU 09/06/2018
On the 8th, late evening the all white CS-TFZ as in front of the LH Technik hangar.
Regards Pieter,
Regards Pieter,
Re: BRU 09/06/2018
And confirmation from FR now; he's on the radar
Re: BRU 09/06/2018
She is on the radar, aircraft are always female
Re: BRU 09/06/2018
Ah, the sex of things!!!
If indeed the sea vessels are always feminine, I seldom hear the same for aircraft. For me they are neutral: "It is on the radar!"
- Vic Diesel
Re: BRU 09/06/2018
It seems the Germans realised that the A343 isn't a very formidable aircraft and started burning them on the apron...nicopapa wrote: 09 Jun 2018, 23:24 It has spent exactly two hours in BRU. That's a long fuel stop! What a waste.
Viktor
Viktor
Re: BRU 09/06/2018
Nothing new, Air France did the same more 20 years agoVic Diesel wrote: 14 Jun 2018, 10:02It seems the Germans realised that the A343 isn't a very formidable aircraft and started burning them on the apron...nicopapa wrote: 09 Jun 2018, 23:24 It has spent exactly two hours in BRU. That's a long fuel stop! What a waste.
It's interesting to notice that a fuel stop may be required for a flight that usually doesn't exceed 11 hours. It's normally well within the A340's capabilities but Bogota airport must be really challenging.![]()
