Diesel/A1 twin prop diamond DA42 flies across Atlantic
Would you buy one if you had the money ?
Total votes: 0
Arvidius
Post by Arvidius »
Amazing:
A new twin prop (diamond da42) has an endurance of over 12 hours and a range of 2500 nautical miles.
Only 22 litres per hour fuel consumption at an average of 152 Knots....
No fuel price problem here...
Estimated buying price for a new model with glass cockpit delivery end of 2005/ beginning 2006 : +/- 400.000 euro
see the following url for more details:
http://www.diamond-air.at/en/press/pres ... /40820.htm
Zorba
Post by Zorba »
Offcourse! It's one of my favorite airplanes at the moment (speaking of General Aviation!) It's amzing what this plane has done !!
Good job Diamond!!
Tot hier en verder
AFApresident
Post by AFApresident »
Who would buy such a small plane for a 12hr+ flight :-s?
for the group some data:
the Thielert Centurion 1.7 engine is build around a daimler block - which the manufacturer doesn't want to acknowledge.
There is a 4 cylinder version already in serial production and a V8 engine in development stage. On diesel.
The manufacturer is Thielert from Germany.
www.thielert.com
They have a manufacturing plant in Hamburg and Lichtenstein, former East-Germany (where there is a lot of new automotive manufacturing thanks to heavy state subsidies)
Thielert is a subcontractor for parts (camshafts, crankshafts, cylinder heads) for sport engine manufacturers, such as Daimler, Porsche.
They have state of the art machinery for turning, milling, grinding, deep hole drilling (to get weight out the camshafts and provide internal oil cooling)
Astonishing is that the oilpan for the serial production 4-cylinder is made by milling a solid block of aluminium instead of using high quality aluminium (sand)castings, as from the Cosworth Foundry UK.
There seems to be something going on in the small world of diesel-engines-for-airplanes. The German company Zoche ( www.zoche.de) has developed also an aero piston engine, but with a complete different lay out. (radial engine instead of line) Zoche seems not te be able to enter serial production. Zoche probably wants to work on the old aircooled Porshe block, for which they have the entire gravity die + shell core casting facility.
Belgian aircraft manufacturer Lambert Aircraft ( http://www.lambert-aircraft.com) has also shifted its interest from the Zoche engine towards the Thielert Centurion 1.7 engine.
I hope the details give the group some satisfaction in the eternal quest to more knowledge.
Thanks for detailed information, regi!
nwa757
Post by nwa757 »
AFApresident wrote:Who would buy such a small plane for a 12hr+ flight :-s?
Because it is a relatively inexpensive plane to aquire and it has lower operating costs than a C-208 for example.
Talk to ya later,
Trevor
Onward and Upward...
liebensd
Post by liebensd »
And maybe in the future you can use "lijnzaad" so you can produce your own fuel. :) You can now already use lijnzaad fuel in your car.
Dave
Vegetable oil, why not? Years ago, there were rumours that McDonnald's would get a franchise in the new A380. Maybe they could not only sell hamburgers but provide fuel as well.
You are allowed to laugh.
