I saw somwhere that the Boeing 777 would have a tailhook in the centre of the fuselage.
Does anybody know what it's used for?
Kind regards
Capt
B777 Tailhook?
Forum rules
viewtopic.php?f=21&t=12716
Re: B777 Tailhook?
The thing you probably saw, was an emergency power generator. Normally, when the eingines are working, they are the ones that provide electricity to for instance the cockpit. If both engines would stop on the 777, this generator would be lowered from the plane's belly. It's very small and can only supply enough power to let the main air-systems work (like airspeed, altitude and direction indication).Capt wrote:Hi,
Kind regards
Capt
Could that be what you have seen ? I know 1 thing for sure, there is absolutelly no 777 with an arrestor-hook.
Re: B777 Tailhook?
I think you mean the "thing" that prevents the fuselage from hitting the RWY when a tailstrike happens. If the crew pulls up to steeply on the runway.Capt wrote: the Boeing 777 would have a tailhook
