SNBA Kinshasa
SNBA Kinshasa
Dear aviation freaks,
On the one o'clock news at TV1 (16-04-04) there was an item about old colonials that were flying back to kinshasa with SNBA.
They were checking in in the old check in hall.
Is SNBA always using the "old" facilities for flights to Africa or was it only this flight?
Regards,
Winglets
Regards,
Winglets
- Sabena_690
Chris, even when people check-in in the old check-in hall, they have to proceed (in this case) to the security control for non-Schengen departures in the new check-in hall, to go to the B-Pier.
Charter airlines like OHY regularly make use of the old check-in hall. And if I'm not mistaken, also CO still uses the old hall.
Frederic
Frederic
That wasn't my question FredericSabena_690 wrote:Chris, even when people check-in in the old check-in hall, they have to proceed (in this case) to the security control for non-Schengen departures in the new check-in hall, to go to the B-Pier.
I just wanted to know wether all pax had to go to the old C-Pier or not ?
- Sabena_690
Oh Yeah you're right, Sorry.Sabena_690 wrote:I think it did answer your question, Chris!
Even when check-in is in the old check-in hall, people have to go to the new check-in hall to go to the B-pier for their flight.
The C-pier is not in use anymore!
Frederic
After reading it all over again I see my mistake.
I should read more carefully !!!
