I have read at A.net and other places that the first prototype of the A380 will be a model that can't actually fly, is that correct? It is meant for groundtests, I suppose...
Why do they do this? After the series of tests, it's useless, isn't it?
Are the other prototypes reconfigurates and sold?
Thanks for your replies!
Buzz
A380 first prototype question
Structure tests are destructive, they fatigue the plane till it breaks. This aircraft has no systems installed, only the structure. Other prototypes that are actually flyable are usually reworked and sold (at a discount) at some point.
Sometimes the first flyable model is retained as a testbed for changes and improvements.
Having been involved in the design/test to production phases, it is actually surprising to discover the multitude of tests etc. required before one new aircraft type gets the ok from the authorities to fly, and once that happens there will be continuous tests and verification of customer problems from the field, designimprovements, derivatives (A380-XXX) etc. to be replicated by the manufacturer necessitating the availability of one or more prototypes for quite some time. Even more so with any new technology, airframe like the 380. Even though a lot of that work gets done thru computer simulation.Structure tests are destructive, they fatigue the plane till it breaks. This aircraft has no systems installed, only the structure. Other prototypes that are actually flyable are usually reworked and sold (at a discount) at some point.
Unless one has actually experienced this process first hand it is difficult to imagine all that is involved.
HTH explain your prototype question
