The airspeed of a Thomsonfly Boeing 737-300 on approach to Bournemouth airport, UK, dropped to 82kt (151km/h), the aircraft stalled, and the maximum pitch-up during the crew's go-around manoeuvre was 44°, according to an Air Accidents Investigation Branch report. The crew recovered control of the aircraft successfully and landed safely from a second approach.
More info can be found here:
http://www.flightglobal.com/articles/20 ... ident.html
Thomsonfly 737 stalled on approach says UK accident report
See
One of the 3 still flying, in his name he was the first...
It starts with one before it becomes a shower.....
Next flights:
27-01 AMS-MNL
31-01 MNL-AMS
Next flights:
27-01 AMS-MNL
31-01 MNL-AMS
Re: Thomsonfly 737 stalled on approach says UK accident report
Suggestion : you could have mentionned in your title, that this incident dates back to September 2007...
Look like the turkish flight experienced the very same thing,a couple of weeks ago in AMS.Very similar incident.
Marc
Not according to the linked article. Here the autothrottle set the power to idle and then left for lunch without the crew noticing. In the AMS incident the autothrottle was still active and thought the plane was over the runway, and in fact turned down the throttle again after the crew manually set it higher.Spotterke wrote:Look like the turkish flight experienced the very same thing,a couple of weeks ago in AMS.Very similar incident.
