SN247/1247 on 07 Nov 2008 : BRU-BRU-Abidjan ?
LX-LGX
Post by LX-LGX »
Seems the A330 had to return to Brussels after departure. At least, that's what I think when I look at BRU's flight info:
12h00 ETD SN247 BRU-ABJ (A330)
12h03 departed from BRU
13h47 arrival in BRU
18h00 ETD SN1247 BRU-ABJ (A330) (new flight number)
(if fuel had to be dumped : the fishermen from the North Sea don't want it anymore, they suggest to dump it above some nimbies in Noordrand or Kraainem next time)
fcw
Re: SN247/1247 on 07 Nov 2008 : BRU-BRU-Abidjan ?
Post by fcw »
Fuel dumping with an A330??? :shock:
euroflyer
Post by euroflyer »
Will the flight now still leave from the T-Gates and therefore bloc one third of the A-Pier for one delayed flight :twisted: Or have they returned to the B-Pier with the plane ?
LX-LGX
Post by LX-LGX »
fcw wrote:Fuel dumping with an A330???
Like most people on the ground, I don't have any technical knowledge about fuel dumping (I didn't get any further then a theorical PPL 25 years ago). And when I was in the rear cabin up high, I've never experienced fuel dumping - hence my question: if...
LX-LGX
Post by LX-LGX »
new departure time : 20h30
(previous one was 18h00).
flip330
Post by flip330 »
and the winning A/c is : OO-SFO
CARS mode: G Aircraft reg: OO-SFO [Airbus A330]
Message label: H1 Block id: 5 Msg no: C87A
Flight id: SN0204 [] [Brussels Airlines]
Message content:-
#CFB.1/WRN/WN0811070209 360030506MAINTENANCE STATUS BMC 2
C-46commando
Post by C-46commando »
SN247 has finally left BRU. The pilot told the PAX there was a sensor problem. Apparently they had to place jacks under the aircraft, so your guess is as good as mine, sensor problem with the bogey, wheels, brakes...
Andries
Post by Andries »
LX-LGX wrote:(if fuel had to be dumped : the fishermen from the North Sea don't want it anymore, they suggest to dump it above some nimbies in Noordrand or Kraainem next time)
The BruAir A330's don't have a fueldump-system. Not sure if there are much 330's around with such a system ...
:twisted: Andries :twisted:
spokkie
Post by spokkie »
You only have fuel dump on A330 when they have a center fuel tank. WItch the 330's of sn don't have.
Now they had a landing gear disagree in flight. This was due to an broken sensor @ the left main landing gear.
The plane didn't dump fuel or flew circles but made a heavy landing. (used litterally the whole lengt of the strip, trust reverser where still active infront of hangar 41, witch says enough imo)
We only put the plane on jacks for the tests that need to be done after the sensor replacement
If i can rember correct the plane left the hangar (41) @ around 19h30.
