Volga-Dnepr Airlines AN124 at EBBR sun 25/1
Forum rules
viewtopic.php?f=21&t=12716
Volga-Dnepr Airlines AN124 RA82045 is parked at the military apron at Melsbroek, someone knows when it will leave?
Thx
Thx
Is it possible that I saw the An-124 fly over Mechelen this morning between 08:30 and 09:00? At first I thought I saw a 747 ( because of the 4 engines ) coming over but when it came closer I saw the roof mounted wings.
AN124,
LZ-CBE is a regular visitor of EBOS too I really like the An-12's !!! They are my second favourite plane after the Ilyushin Il-76.
http://www.planepictures.net/netshow.cgi?166480
http://www.planepictures.net/netshow.cgi?166483
LZ-CBE is the last one in this line-up of 3 An-12's and 1An-26.
Long live the russian smokers
CanonFreak
CanonFreak
Meerkat,
I think this is one of the ex Silk Way DC8's.
See also this picture at airliners.net
http://www.airliners.net/open.file/465636/M/
I even believe that this is the one that was grounded by dutch aviation authotities because of some technical problems.
I think Canonfreak can tell you more about this bird.
Best Regards,
Yvo
Best Regards,
Yvo
This is ex-Silk Way 4K-AZ25 indeed. 4K-AZ29 allready left EBOS. She will soon start flying with Johnson Air, probably again from EBOS. The same faith probably awaits the 4K-AZ25, the one you saw, meerkat.AN124 wrote:I think this is one of the ex Silk Way DC8's.
The new fences are horrible !!! :pang: :pang: :pang:B737229 wrote:Sure OST is a very interesting airport to visit, but is it still as good as before to make pic's?
They made a safety fence around the field, but I havent been there since.
Is it still possible to make pics at the touchdownpoint of rwy26, (at the gate) and at the threshold of 08?
They are about 3m high and the holes are about 5cm x 5cm, so way too small for poking your lens through.
You need a good ladder now if you wanna take pictures at the toucdown point of 26. And I do mean a GOOD ladder, one that takes you about 1.5 - 2m above the ground. Also you can't get as close to the runway anymore. Where the road turned toward the runway, that's where it has been cut of by the new fence. As you can see on the next picture, you can't get to the end of the road anymore.
http://www.airliners.net/open.file/484962/L/
About 08 ... no problems (yet). If your standing inside the Kalkaert, you still have the old fence of 1m20. So no problems there. If you're standing at the entrance of the calcaert, you have another fence. This fence is made out of parallel poles with a gap of about 15cm between them. You can easely take pictures of aircraft taxiing for takeoff. so no problem here either. If however they com in on 08, you can't take anymore approachshots from this spot, unless you got a ladder (again). If you do want to take app. shots, you should walk about 100m to the left, where the aircraft are still higher and the fence is not in the way yet.
You can understand that EBOS has become a nightmare in photograpy if you dint have a car and a ladder. I always go there by bike and I don't have a ladder ... so usually I go inside the Kalkaert, wher you still have the old fence.
IF you want to go into the Kalkaert, park your car at the entrance and go inside on foot ! Otherwise you might get some problems with the boss ...
He once delibberetly closed the gate while a friend of mine was inside with his car. The boss called the police and my friend allmost got a fine for trespassing ... But if you're on foot or by bike, they don't do that. You can allways leave, even if the gate is closed as they have a gap of about 1m wide next to the gate where you can just walk through.
If you got anymore questions, just ask'm.
CanonFreak
- Vonsmalhausen
