DUB is lacking Boeing 747s
Share pictures, log-reports, special aircraft, nice events, hints and tips
BA028_Is_Diesel_Powered
Post by BA028_Is_Diesel_Powered »
This is the worst news to hear. Hardly any 747s can been seen at DUB. Because Aer Lingus made the wrong decision getting rid of their Boeing 747-100s and changing to Airbus 330-200 & 330-300s about 10 years ago.
There's only one scheduled 747 flight to DUB every Tuesday or Wednesday and only staying for a day! It is a SQ (Singapore Airlines) Boeing 747-400F. The bad news is that it doesn't carry any passengers because its a Cargo Plane :( . There is some unscheduled Boeing 747s at DUB but rare. Once I saw a B 742F landing at DUB and anout 2 months after that I saw a Alitalia 747 200 or 300 taking off. There should be a Aer Lingus route from DUB to HKG weekly or monthly. Its only about 14 hours flight to HKG! Save loads of time changing in LHR and CDG. I think Aer Lingus should buy 2 Boeing 744s. :D To increase 747s @ DUB :)
Hi Diesel
Don't worry! There are hardly any B747s at BRU either since SQ cancelled their MAN-BRU-SIN flights.
Lyulka
Post by Lyulka »
I think it has been worse: now we get almost daily a SIA Cargo flight, a Cathay pacific/Air Hong Kong, a Saudi Arabian one and the Korean one (Asiana). There are also rather regular services with RAM 747's , Egyptair uses them from time to time, and we've got the Hydro Air one, which is a catch for non EBBR people (as far as I know it can only be seen at Johannesburg , Ostend and Brussels). Thursday before let's say 1200h, you can see 4 of them. And when the SARS crisis is over we will probably get the SIA aircraft back, which are also sometimes two flights a day. Give me a 777 please. Just 1 every week (SIA?).
Sabena_690
Post by Sabena_690 »
Hi Lyulka,
I have to dissapoint you about SIA: it's not official yet, but they will probably close BRU for pax operations.
They have a codeshare with LH on the BRU-FRA leg, and pax will be able to fly to SIN via FRA (with 3 daily departures: 2 op. by SQ, one by LH).
Regards
Frederic
Lyulka,
There is a weekly 777 depature on Fridays to Cairo by Egyptair.
sn26567 wrote:Lyulka,
Indeed!
as photographed by Paul Jongeneelen!
https://www.aviation24.be/modules.php?op=m ... erby=hitsD
Can you imagine: changing al those 4-engined AVRO's at Brussels airport into brand new Boeing 777's!!! :wow:
Keep on dreaming....
ciao,
:rock:
Lyulka
Post by Lyulka »
does it usually land at 25L or R? At wat time does it normally arrive?
MS759 (Boeing 777-200) arrives from Cairo on Fridays at 14:50.
25R or L? Depends on the humour of ATC :wink:
Sabena_690
Since the aircraft arrives at Pier B, it will most likely arrive on 25L.
Note that MS regularly switches between a/c types. It's no problem to see this week an A320 and an A321 of them, and next week a B772 and a B743.
Regards
Frederic
Lyulka
Post by Lyulka »
you forgot the A340 and the A300 , or the midwest A310 (haven't seen it for a while, think it is only used in summer time). :)
sn26567 wrote:MS759 (Boeing 777-200) arrives from Cairo on Fridays at 14:50.
Hi all,
here is a small rule for landings on runways 25L or 25R:
25L :arrow: passenger-aircrafts are supposed to land on 25L
25R :arrow: cargo and private landings on 25R unless the ATC-controller sees it different. Most of the time the ATC-controller agrees to a 25R if the parking-position is at Terminal A even-positions (southerly positions)
If the Egyptair Boeing 777 will show up at BRU it will land at runway 25L 99,99% chance.
If an RJ85 will park at the A-pier south-position the controller suggests 25R or the pilots suggest 25R. If this aircraft should land on 25L a lot of apron-movements and a lot of fuel will be used to arrive at the parkingposition.
greetings,
:dance:
Andries
Post by Andries »
Lyulka wrote :
and we've got the Hydro Air one, which is a catch for non EBBR people, as far as I know it can only be seen at Johannesburg , Ostend and Brussels ...
Hydro first came to Ostend but then changed to BRU. We haven't seen Hydro at Ostend since then. :cry: :cry: :cry:
Meanwhile we've got 2 to 4 Kalitta Jumbo's per day ... :lol: :lol: :lol:
EBOS
EBOS,
Do you know their schedules because I would like to spot them???
greetings
:jumpy:
Andries
Post by Andries »
The Kalittaflights don't have a certain our at which they come in, because they are military flights for the USAF. You CAN find their schedules on :
http://www.kalittaair.com
:twisted: EBOS :twisted:
Andries
Post by Andries »
I forgot to mention that you can also see them on VRT teletekst page 383.
CKS = Kalitta, RCH = Reach and usually is Kalitta, but sometimes also Evergreen International (also 747). In the last weeks, only the kalitta's have been at Ostend.
Lyulka
Post by Lyulka »
some time ago I saw a 747 at EBOS registred as n714ck. Is this one of the few 747-100 which had a military cargo convertion, or is it a 747-200? In different lists I found different types, both the 100 and the 200. I assume it was operating for kalitta for the US to Kuweit. Are there any external differences between a 100 and a 200?
Lyulka wrote:Are there any external differences between a 100 and a 200?
If I remember well (I did not check anywhere), a 747-100 has three windows for the lounge at the top floor, whereas a 747-200 has some 8 to 10 windows.
meerkat
Post by meerkat »
N714CK is indeed a -200.
It is a 747-209B(F) c/n 22446 l/n 519 delivered to China AL of Taiwan as B-1886, re-registered B-18753, converted to freighter and then to Kalitta as N714CK. no dates on my own database as yet but a bit of research on the net will give this info.
Meerkat :wink:
liebensd
Post by liebensd »
Brussels and Ostend are not the only place where 747 come. In Liege there is a regular CAL Cargo Airlines flight to Tel-Aviv (and New-York I think). You can see there also Belgians only 747-400 OO-TJA of TNT Airways. For more information about the arrivals and departures look at there side.
http://www.liegeairport.com/destination ... rameS.html
greets,
Dave
I thought OO-TJA would be gone again in april, that's what I heard a few weeks ago.
Can somebody tell me more about it???
regards
:dance:
