Vexje wrote:Had a delay once with SN for technical and got rebooked on another, taking pictures a different intervals I could prove they did not everything possible to resolve and forced them to compensate me.
I took pictures of 4 aircraft standing on the tarmac for over 4 hours (while my MXP rt flight would have taken then little under 4 hours), did they everything to resolve, I don't think so, on the other my flight had only 16 pax booked, so maybe that was the real reason.
I would still ask compensation, and maybe get a nice ticket out of it, the harder you nag, the more impatient they get and hand you morejust to get rid of you.
So because SN has spare aircraft on the tarmac, they should just take another aircraft and put it on your MXP flight
If it would only be so easy...
x from reloading the catering/bags & reboarding the passengers to dispatching another aircraft to/from MXP and preparing this aircraft in BRU for the next flight, you need much more than 4 hrs
x even if you have an aircraft available, you also need a reserve crew (as you'll build up a delay, so the crew wouldn't be back in BRU on-time for the next flight, or in case the crew had flights before they might be getting out of hours)
You cannot just take a picture of an SN aircraft on the tarmac and claim that SN hasn't done everything to operate your flight, that's just a bit too easy, right?
You also can't say that they cancelled your flight because there were only 16 passengers, as you don't know the number of booked passengers on the return flight.
Whenever there is an aircraft that cannot operate a certain flight for whatever reason, an airline company will always check if there is a spare aircraft available. If this is not the case (even if you see 10 aircraft parked on the tarmac), they'll cancel your flight (brussels airlines flies 5x daily to MXP so you can always rebook the passengers onto the next flight). At SN an aircraft change is a very common procedure by the way to sort out (operational) problems and it happens every day, so it's not like SN will just cancel a flight if they don't have to.
