A KLM MD11 from Curacao was forced to land after crew noticed lack of fuel.
Read it here
KL763 short of fuel, forced to land short of destination.
Luchtvaartnieuws.nl reports that the fuel shortage was caused by a combination of strong headwinds (stronger than was predicted) and a long period of flying at a relatively low altitude. These two things caused a much higher than anticipated fuel burn, which is why they stopped in Ireland for a refill.
- Flying-Belgian
sn-remember
Sure they use them for longer trips, but nobody wants to take more fuel than they think they will need.
In addition, nobody said the 150 minutes were spent on the ground. They even mention headwind as one of the causes for the fuel shortage, which would indicate to me that the flight took them longer than anticipated, hence the delay.
foxtrot_lima_yankee
There is the Azores halfway Curacao to Amsterdam.foxtrot_lima_yankee wrote:
Lucky those winds were not a bit stronger, otherwise they might have been swimming around somewhere in the Altlantic about now.
They have experiences about airplanes without fuel :
http://www.airdisaster.com/cgi-bin/view ... ir+Transat24 August 2001
Airline: Air Transat
Aircraft: Airbus A330-243
The aircraft was on a flight from Toronto, Ontario, Canada to Lisbon Portugal when a problem developed with the fuel system approximately 300nm northeast of Terciera Island, Azores Islands, Portugal. The crew elected to divert to Terciera Island for an emergency landing. The Captain reported that approximately 100nm from the airport, the left engine failed, and some ten minutes later, the right engine failed as well. The aircraft, using a minimal amount of hydraulic and electrical power supplied from its Ram Air Turbine, continued gliding toward Terciera Island in a gradual descent. The Captain reported that the flight arrived over Terciera Island at FL150 (15,000 feet), at dawn, and so he elected to make a visual approach to the airport with no engine power.
The total flying time without engine power was in the neighborhood of 17 to 18 minutes. The aircraft sustained minor damage during the landing, including damage to the landing gear as twelve tires exploded upon touchdown.
Initial reports indicate that a fuel line which had been replaced several days before became severed, leading to a fuel leak of approximately 37,000 gallons over the Atlantic Ocean.
sn-remember
and crossing the ocean, you might expect an addtional security fuel.foxtrot_lima_yankee wrote:I would rather take too much tan too little fuel...
certainly for long haul flights.
But we all know the Dutch, they think otherwise![]()
Incredible thos dutch
