Goodmorning,
Half Octobr I had the pleasure to be on 2 SNBA-flights, both with Avro. I have 2 questions about what I saw and experienced.
What I saw : On the fuselage of the Avro you clearly can see 2 black dots but I do not know their function or what is kept behind.
See : http://www.airliners.net/open.file/419106/L/
What I experienced : On take off after a few minutes it looks like the engines are going to maximum power and the engines make that much noise that you get the impression that something is going wrong although I know it is not. Than at a certain moment it stops and you do not hear the engines anymore. Sound a little bit silly the way I explain this but I do hope people know what I mean and that it can be explained.
Regards, Karl
Avro-airplanes
Fiero
- Comet
The Avro types make much less noise on take off than other jets, that is another reason that they are so welcome at London City (that airport is in a largely residential area in London).
It is a bit disappointing when you like the pre take off engine roar of other types (nothing beats the roaring fours of the 747-400 in my opinion).
Louise
Louise
Well, I don't know what you heared but the engines aren't that loud. All I know is that the flaps are loud inside an Avro. That's maybe what you hearedWhat I experienced : On take off after a few minutes it looks like the engines are going to maximum power and the engines make that much noise that you get the impression that something is going wrong although I know it is not. Than at a certain moment it stops and you do not hear the engines anymore.
Greetz
8)
