BRU 12/11/2006
Forum rules
viewtopic.php?f=21&t=12716
- Established02
BRU 12/11/2006
5 SQ + 2 CX + 1 SV + 1 KE + 1 K4 = 10 747 freighters today
LAX-BRU is that without payload restrictions for SQ?
11/11 19:25 Los Angeles SQ 7881 landed 07:26 74Y
12/11 09:40 Singapore via Dubai SQ 7366 landed 10:14 74Y
12/11 16:10 Singapore via Johannesburg SQ 7344 landed 21:07 74Y
12/11 19:20 Chicago ORD SQ 7895 landed 18:02 74Y
12/11 20:00 Los Angeles SQ 7883 landed 19:48 74Y
12/11 11:50 Hong Kong via Dubai CX 061 landed 12:15 74X
12/11 15:30 Hong Kong via Dubai via Manchester CX 001 landed 16:09 74X
hansvandedonk
Re: BRU 12/11/2006
just checked flightplans 7881/7883.Established02 wrote: LAX-BRU is that without payload restrictions for SQ?
now a small calculation :
mtow 394625kg
dow 160000kg (average)
gives you 234000kg (roughly) to be divided between fuel and payload.
average flightime 09h05-09h20 at +- 11000kg/hour gives a burn between 96000kg and 100000kg. Add to that some other fuel requirements such as 3pct contingency/alternate fuel/excess fuel required due to fuel policy,..... gives you average block fuel of 110000-115000kg. Result is close to max payload.
Note fuelfigs all depend on weather conditions (ie windspeed in the jetstream reached 150kts yesterday)
motorcycling : sensation with a twist of the wrist
Wrong answer, was CN-RPB on a maintenance check, check also November Spotters DBTUB001 wrote:Should be OO-TUM, flying for Jetairfly as well.hansvandedonk wrote: Request: Jet4You 737
The white A310 is OE-LMP, arrived July 2006, check also July Spotters DB
Kalitta was N703CK, regis can be picked up via Kalitta Air web.
hansvandedonk
- Established02
Re: BRU 12/11/2006
Thank you for the science, 744rules.744rules wrote:just checked flightplans 7881/7883.Established02 wrote: LAX-BRU is that without payload restrictions for SQ?
