31/08: SN Brussels Airlines A333 emergency landing?
JM
Post by JM »
hello all,
just saw an SN A333 take off from RWY20, but it flew very low with gear extended... It didn't go higher than 5000 ft...
Anyone got info ?
JM
31/08 11:50 Brussels SN 351 ... ARR
31/08 10:40 Kinshasa SN 1351 13:00
via Douala DEP
EDIT: apparently problem with right engine... it landed on 25R 5 minutes ago (1215)...
star alliance
Post by star alliance »
hello,
On the news they said that the plane had a problem with one of his engines. SN Brussels is now searching a solution for the passengers.
Best regards
Star alliance
speedbird1
Post by speedbird1 »
Which 330 is it this time? I saw the other day that SFM had a problem coming out of Brussels.
Emirates
petarn
A 330
Post by petarn »
I was there when the plane arrived with the firemen and police...
I'm tecnician
He had problems with the right engine on take-off.
It was not a problem of maintenance!!
greetings
LX-LGX
Post by LX-LGX »
There's a new departure scheduled for 17h30 (also A330-300)
flight number is SN1353 = Brussels-Kinshasa-Douala
(scheduled this morning was SN351 = Brussels-Douala-Kinshasa)
AF332
Noodlanding op Zaventem lokt wrevel uit in buurgemeenten
Post by AF332 »
This article is only available in Dutch:
31/08 Noodlanding op Zaventem lokt wrevel uit in buurgemeenten
Een SN-vliegtuig is donderdagmiddag naar de luchthaven van Zaventem moeten terugkeren wegens pech aan een van de motoren.
De Airbus A330, die Kinshasa als bestemming had, kon rond 12.15 uur zonder brokken landen, maar de noodlanding veroorzaakte onrust in gemeenten die in de omgeving van de luchthaven liggen.
Verscheidene mensen zagen het toestel "op minder dan 200 meter hoogte" over bewoonde zones vliegen. Van de kant van luchtvaartmaatschappij SNBA werd echter gezegd dat de noodprocedure op geen enkel ogenblik enig risico inhield.
De burgemeester van Sint-Pieters-Woluwe, Jacques Vandenhaute, en die van Wezembeek-Oppem, François Van Hoobrouck, stelden het gebruik van baan 20 van de luchthaven aan de kaak, die volgens hen te kort is. Ze namen ook het spreidingsplan Anciaux op de korrel.
URL: http://www.hbvl.be/nieuws/Binnenland/de ... 2C9C014580}
Philippe
LX-LGX
Post by LX-LGX »
Content of that press article:
Seems many many members from many many anti-airport committees have seen the big bird in problems, and they don't like it.
Even some mayors now protest. That's strange, as one of them was a Business Class passenger on that same SN351 just two week ago: as a member of parliament, he was going to witness the elections in Congo.
JM
Post by JM »
LX-LGX wrote:Content of that press article:
--> exactly !
Every given opportunity is recieved with open arms !
The flight of ALX was also delayed. Could it be that SNBA made and arrangement with them to took over some pax for transport to FIH?
I hope for SNBA that they could resolve the current problems with the A330's.
Sparrow
Post by Sparrow »
Atlantis wrote:I hope for SNBA that they could resolve the current problems with the A330's.
I don't think so. 2 of the 3 flights to Africa tomorrow are cancelled. The Dakar flight was first delayed to 13.00, and is now also cancelled.
I think that SNBA have some serious problems with their A333. But what I don't understand is that they have received a full check, some months ago. No?
Kind regards
Bavo
Jense
Post by Jense »
SFM had an engine failure (no° 2) and was parked at the old C-pier. No more info from my side...
benybird
Post by benybird »
I have witnessed the landing. The airport was closed for a few minutes after the crew declared the emergency. The approach and the landing were absolutely normal. Only the trained eye could see the bank into the good engine to compensate for the assymetric thrust.
Except for the numerous firetrucks at the RWY edge there is no way that any of the surrounding complainers could have noticed anything unusual with that AC. No way josé that it flew lower over the neighbouring houses than it would on two engines. I also noticed during the taxi back that both engines were turning so the failed engine did not stop entirely.
EBAW_flyer
Post by EBAW_flyer »
But I saw the aircraft climb-out and below 1000' its climb rate was reduced significiantly. That probably worried the inhabitants. Its initial climb was ok, until a 3-400ft when I noticed the gear wasn't going up and plane wasn't climbing the way it should.
Andries
Post by Andries »
Atlantis wrote:I think that SNBA have some serious problems with their A333. But what I don't understand is that they have received a full check, some months ago. No?
If I remember correctly, they got maintenance done at SR Technics in Switserland (both airframe and engines) Very strange indeed that after such a short while the A333's are starting to get problems ...
But, as petarn said, it was not a problem of maintenance. Maybe there was a birdstrike or something similar.
I am curious to hear what the reason was !
:twisted: Andries :twisted:
Kapitein
Post by Kapitein »
During take-off, flames where spotted at engine number 2. This can point indeed to a birdstrike.
Johan23
Post by Johan23 »
For me the reaction of the inhabitants of overflown towns was hilarious. One woman even claimed that the a/c flew only 10cm overhead their building. It's a pitty that politicians and inhabitants use this event to try to forbid take-offs from rwy20. I think a black list with people who are always nagging against the airport would be a good idea. Once on the list you are forbidden to fly on airline flights. This to prevent sheep from following the rest of the flock, as a lot of persons are signing petitions because their neighbour does!!!
Ban the anti-airport people!!!!!
Johan
744rules
Post by 744rules »
Looks to me the crew handled the emergency very professional.
As for the complainers : note that we have elections coming.
In the newspaper, some even think the engine failed as it was running at max power on a short runway :?:
As if this problem couldn't happen on 25R :!:
I would file these complaints under nimby
motorcycling : sensation with a twist of the wrist
Sparrow
Post by Sparrow »
If it was a birdstrike it could happen everywhere, also on runway 25R. But then was the emergency process much longer than it was taken off yesterday on runway 20.
Johan23 wrote:For me the reaction of the inhabitants of overflown towns was hilarious. One woman even claimed that the a/c flew only 10cm overhead their building. It's a pitty that politicians and inhabitants use this event to try to forbid take-offs from rwy20. I think a black list with people who are always nagging against the airport would be a good idea. Once on the list you are forbidden to fly on airline flights. This to prevent sheep from following the rest of the flock, as a lot of persons are signing petitions because their neighbour does!!!
Johan
I don't understand these people. The problem with the Airbus could also been an other aircraft, even a Boeing. But I think if some of these people were in that aircraft for their flight to Africa. I think that some of them were happy that they are back on the ground. Then there was no reaction of the inhabitants.
And if the Airbus was only 10cm overhead their building, then she had an other problem I think. She had to do some roof construction, with all her flowned roof tiles. :lol:
Kind regards
Bavo
Johan23 wrote:It's a pity that politicians and inhabitants use this event
It's true that Rwy20 is not the safest one. It is shorter that the 2 Rwys 25 and therefore its use with wide-bodies should be avoided.
But it is also longer than the only runway of CRL!
petarn
hello
Post by petarn »
I can tell, it was not a birdstrike...
there was nothing seen external at the engine, it was internal, but you can not see that like that, they can see with special tooling...
maybe something was broken in the combustor.
greetz
