Does Biman Bangladeshi Airlines have lots of safety issues?
Does this airline have lots of safety problems?
Theres nothing better than slow cooked fall off the bone BBQ, Texas style
- speedbird1
I remember some years ago on 'het leven zoals het is: Luchthaven' that the company wasn't that very strict on safety related items. (rebroadcast of that programme soon on belgian television)
There was a severe engine-leak but the captain just minimized the problem. A don't think that's a safe attitude if you have to cross the Atlantic...
Greetz
Greetz
Beware that engines loose fluid on a normal bases, this is not always a technical problem.camel wrote:I remember some years ago on 'het leven zoals het is: Luchthaven' that the company wasn't that very strict on safety related items. (rebroadcast of that programme soon on belgian television)
Greetz
Greets.
Robin_Bamps
I was quite a fan of the series and if I remember correctly, it wasn't an engine leak but a hydraulic leak on the front gear. The captain indeed minimized the problem with the historic words "Only a leak ?!". However, Sabena Technics did the reparation.JoNnika wrote:Beware that engines loose fluid on a normal bases, this is not always a technical problem.camel wrote:I remember some years ago on 'het leven zoals het is: Luchthaven' that the company wasn't that very strict on safety related items. (rebroadcast of that programme soon on belgian television)
Regards, Robin Bamps.
- Tommypilot
It was an oil leak on the third main gear, not the front gear. There was a "joinke" damaged and needed to be replaced. Due to the gross weight the third main gear couldn't be retracted so they had to replace the "join"(or how do you write it?)Robin_Bamps wrote:I was quite a fan of the series and if I remember correctly, it wasn't an engine leak but a hydraulic leak on the front gear. The captain indeed minimized the problem with the historic words "Only a leak ?!". However, Sabena Technics did the reparation.
Regards,
Tommy
The word "impossible" is not in my dictionary! - Napoleon Bonaparte
It was NOT necessary to replace the oil strut seal, so they did NOT replace the seal because it was just a bit moved, mechanics compressed the strut to make the seal came back in his original place and the leak was gone.... so we come from a engine oil leak to a hydraulic leak on the nosegear and in fact it was a minor oil leak at the strut of the Body gear... I think if you do a proper walk around the aircrafts at Brussels Airport you will find some minor strut leaks or not correct pressurized struts please make sure you know the facts before you reply...... no offence but this way we get some amazing storys that never happened....
- Tommypilot
Sorry I messed UP the seal with that one of a SLR engine during the series...lucky us that you remember the facts!Bilboone wrote:It was NOT necessary to replace the oil strut seal, so they did NOT replace the seal because it was just a bit moved, mechanics compressed the strut to make the seal came back in his original place and the leak was gone.... so we come from a engine oil leak to a hydraulic leak on the nosegear and in fact it was a minor oil leak at the strut of the Body gear... I think if you do a proper walk around the aircrafts at Brussels Airport you will find some minor strut leaks or not correct pressurized struts please make sure you know the facts before you reply...... no offence but this way we get some amazing storys that never happened....
Tommy
Biman should cease operations very quickly
They seem to have come to the end of their rope!
http://www.financialexpress-bd.com/inde ... 08&spcl=no
The last Biman flight to New York flew today.
Cash-strapped national carrier Biman suspended yesterday flights to New York in a bid to cut massive losses and said it plans to halt services to other international destinations soon.
Biman lost $149,210- for every flight to New York.
Biman would also soon suspend flights to Frankfurt, Paris and Yangon.
Last October it was approved to sell 61% of the company to private investors , and euh.... the waiting room stayed pretty empty...
*In Bangladesh money: 10.4mn taka, at the todays rate the loss will be 149,210 US Dollar = 10,659,413 Bangladeshi Taka....
About 275USD for every saleable seat
- fokker_f27
That must have been the last flight then. It's a good desicion I think. They will have to fly only profitable routes if they want to survive. Then they can finally renew their fleet with more fuel efficnt aircraft with working airco and lavatories.cityflyer wrote:Yesterday, (Saturday) I saw a Biman DC10 on approach in Brussels.
The most sexy girl in the sky: The Sud-Est Caravelle 12.
