Pushback ?
Pushback ?
Hello ! I'm a regular flight sim player but i'm not able to turn the plane in any direction during the pushback and i heard that it was possible. Can someone help me ? There is something to do with the numbers but wich numbers and when do i need to push on them ? after SHIFT+P or at the same time ? Thanks a lot for the help. Olivier :plane:
- Skyfighter
reply
So what you have to do...
you push SHIFT+P+1
you push SHIFT+P+2 (other direction)
Firsy you do SHIFT+P and 1 or 2 seconds later you push the 1 or 2 button (not the buttons on the right of your keyboard but the one above,under the F1,F2,F3,... keys)
It is possible that it take a wile before he turns,so be pacient
Greets
you push SHIFT+P+1
Greets
