Near Miss? You Decide - 6 pictures
I was in London on the weekend and can confirm the weather was a perfect winter day with not a single cloud + lot's of visibility.
I often notice when you fly to Heathrow and your kept in a holding pattern over the east end, that you often see other aircrafts not very far away. The skies are so congested that the ATC keeps them to the max allowed distance.
This incident was more of a scare from the ground than a real danger for both planes.
- speedbird1
- speedbird1
- Advisor
This near miss is scary ChiefEmirates wrote:Yes I know, but do you notice one thing...? They are all the same!mafrick wrote:There are 6 pics. You just have to click on the "next" button
Emirates
Aum Sweet Aum.
- speedbird1
I am sorry they are indeed different. I think it was just that they are obviously taken on a 6 frame burst or something. I was just expecting some new pics not just (a) the ones that are over all the papers and (b) ones that are minisculely different. Pardon memafrick wrote:No, they are not all the same. If you look closely you will see a difference between the pictures, fe the distance from the DHL nose and the tail of the 777.
Emirates
Reported in todays new papers,
The Japan Airlines Boeing 777 was actually 1,000ft higher than the DHL Airbus A300. It was also 3,198ft away from the other plane.
But the angle for shocked watchers on the ground meant the Heathrow-bound jets appeared as if they were almost touching.
The two planes were not breaking any strict rules for the minimum distances between aircraft.
http://www.mirror.co.uk/news/tm_objecti ... _page.html
Depends on where you are. Oceanic routes everyone at certain flight levels MUST fly at the same Mach number. In radar contact, I guess anything is possible.can a plane be 1000 verticaly apart in cruise? ie a 744 overtaking a 767, the 744 on FL360, the 767 on FL370?
