The DAS AIR DC10 parked on apron North is 5X-JOS, the reg of the one at Brucargo is unreadable due to the haze (it has also small ANA-tiltles, just like 5X-JOS, maybe that can help identifying it)
@ concordino,
are you sure that the registration of the ABX 767-200 N101DA was and not N740AX.
I know there is a big difference between the 2 but the reason why I ask this is that in our system we have got N740AX and not N101DA.
I saw the 767 from Abelags just before it left, with a pair of 12x50 Binoculars I can confirm that it was N101DA (at least that was what was printed on the airframe)
I too was informed that the 76 was carrying an ABX registration but was surprised to read it off as N101DA. N740AX is a reserved reg and will presumably be applied after conversion. This shows how careful we all should be and confirm what is on the plan with the actual aircraft.
