How much water did A380 001 take on board?
To test its gravity centre in flight, A380 001 took a lot of water on board.
Movable water tanks in the front and rear will be adjusted during flight to alter the centre of gravity.
Following an in-depth study, two test flight programmes and numerous laboratory and simulator tests, A380 engineers have also succeeded in moving the aircraft's centre of gravity aft by around six %.
This modification, coupled with a state-of-the-art fly-by-wire system, has facilitated a reduction of roughly 40 square metres in the area of the horizontal stabiliser and a consequent saving in weight*, while preserving the stability of the aircraft in-flight.
The A380 uses also some Concorde technology – it pumps fuel between tanks to balance its centre of gravity through the flight.
Now, does somebody know how much water?
bigjulie
bigjulie
As a test I can understand they would not simulate a full load of passengers.liebensd wrote:it was almost 20 tons of water. The water was mentioned to demonstrate the weight of the passengers.
But a first glance this is not even half full: and then to consider there is not even taken into account galleys and catering, sanitary water in the toilets, the amenities and last but not least the cabin crew....
Some people told me once, it was more difficult to fly an empty aicraft than one with a load.
Was the water not rather a fluid 'chuckable' ballast?
Weight problems continue to be a major concern, I don't think we are going to see many swimming pools,deli's, and all the other stuff people were dreaming about. Fact is you'll probably have to take your own lawn chair.
http://travel.timesonline.co.uk/article ... 93,00.html
bigjulie
bigjulie wrote:Doesn't Boeing use the same technology, for weight ballancing during flight; I am still waiting for an answer to this question, anybody know![]()
Anybody care
Hi Bigjulie,
Just wanted to help out a little, You are correct, Boeing uses computer controlled water tank system to move weight around fore and aft as well as side to side, however when I was just getting into the Airline Industry I was lucky enough to attend Boeing's first flight of the 747 at Everett Washington, and if I remember correctly they used sand bags at that time.
KT
Isn't water heavier than sand?bits44 wrote:I was lucky enough to attend Boeing's first flight of the 747 at Everett Washington, and if I remember correctly they used sand bags at that time. KT
On the other hand, when one crashes with sand ballast, he bites the ...
dust?
DU was also used: it's almost twice as dense as lead. DU has also been used as ballast, weights or counterwights, on ships, satellites and aircraft. Each B747 required about 1500 pounds of ballast (or counterweights), and as many as 15,000 DU weights were manufactured for this purpose. In recent years, DU has been replaced by tungsten in aircraft ballast.
The ELAL that crashed in AMS, was carrying 282 kg of DU as ballast, and a B747 that crashed in England in 2000 was carrying 1500 kg of DU.
Even in 1904 the Wright brothers needed a ballast: a 70 pounds of iron bar ballast was fixed to the front elevator to move the center of gravity farther forward. The weight of the aircraft then increased to about 900 pounds with the pilot. The ballast improved the handling of the aircraft and Wilbur was able to complete the first circuit of the airfield on September 20, 1904.
I remember also having to add sanitary water on a B707c (the mixed version Sabena used to fly), just to get the (empty) aircraft in balance over Lake Vic.
And I once saw this notice: With water ballast on board aerobatics are not permitted.
