[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1091: Undefined array key 0 [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1091: Trying to access array offset on null [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1098: Undefined array key 0 [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1098: Trying to access array offset on null [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1098: Undefined array key 0 [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1098: Trying to access array offset on null A380 airbridge: your opinions needed - Aviation24.be
Hello all, As part of my final year project on an Aerospace Business Systems degree I have chosen to design a new airbridge to board passengers on both levels of the new A380.
In order to make the airbridge stand out from the rest I have come up with three different directions I can take it in. The first is to have windows along the airbridge. The second is to have a transparent roof. The third option is to have a transparent airbridge, and this is where you guys come into it, hopefully. I though it would be a good idea to conduct some market research and ask you folks to decide. So please take part in the poll. Your comments would be most welcome and i will let you know the results. Thanks
I voted for a transparent airbridge, but have to add a non transparrent floor ! Otherwise you could look up under the skirts of the women boarding the upper deck ...
Standard airbridge with transparent walls only: it is always nice to see where you are and where you go. But a transparent roof would change it into a sauna.
I voted for a standard airbridge with windows because if you had windows on the roof, it would be difficult to clean and look dirty like Air France's planes .
I voted for a transparent airbridge, but without a transparent floor. I'm not sure if a transparent roof will make a big difference in temperature. Correct me if I'm wrong but that's how the airbridges are in BRU pier A.
I voted for the standard airbridge becuase it seems the cheapest. (I could be wrong.) Airports are having to spend millions of dollars already so a fancy jetbridge is not that high on my priority list, nor do I think it's high on the lists of airport managers.
thanks for the input guys, good point about the roof giving the airbridge the sauna effect, thats definately somethin i can put in m comments. hopin for a few more votes and il take a screen print of the results, is that o.k?(administrators)
I think an all-glass airbridge is actually more like a greenhouse than a sauna.
Anyway there should be some way to look outside when you're in the airbridge, the ones at WAW have no windows whatsoever, not nice IMO.
Andries wrote:I voted for a transparent airbridge, but have to add a non transparrent floor ! Otherwise you could look up under the skirts of the women boarding the upper deck ...
Also you might have people that are a little bit afraid of height, I mean people that are okay in 'planes for height, but are a little unsteady on their feet on a transparent walkway even a few feet off the ground!
