The crew onboard the Gulfstream identified themselves as "the Special Removal Unit" during radio communications.
Its tailmark has recently been changed from the code N379P to N8068V.
These lines come from the mentioned article, based on a The New Yorker magazine investigation.
The first link is to a South African mainstream opinion pressmedium: it is also interesting to read and to see how they think about let say European society.
Also good to know: (in case things get locked... )
Permission for Use of New Yorker Material
Condé Nast welcomes requests for reuse of New Yorker material. Please make such requests as directed below; if we do not hold the rights to the material in question, the Rights and Permissions Department will do its best to direct you appropriately.
If you would like to reprint or otherwise use an article, illustration, or photograph from The New Yorker, please send a fax to:
Condé Nast Rights and Permissions
Attn.: Leigh Montville
FAX: 212-630-5883
Gulfstream crew identified as the Special Removal Unit
