Air Belgium in 2018
Re: Air Belgium in 2018
Kapitein wrote: 12 Apr 2018, 11:46 OO-ABB ferry to CRL 13/04 STD: 0830LT in BRU
09:00 is expected weather permitting.
https://www.aviation24.be/airlines/air-b ... i-airport/
luchtzak wrote: 12 Apr 2018, 16:39
Postponed till after the weekend due to low visibility at Charleroi, the visibility is required for PAPI test.
Indeed the PAPI is set for ICAO Code "C" aircraft, i.e. B737 or A320.
EBCI AIP PAPI Restriction.png (9.15 KiB) Viewed 5696 times
The PAPI at EBCI gives a visual signal centred around 3 degrees above the horizontal plane and provides an MEHT (Minimum Eye Height above Threshold) of 59ft (18m) on RWY 25.
The aircraft wheels must pass over the threshold with a minimum clearance, when the pilot's eye are at the lowest part of the "On-Slope" signal.
An A343 in approach attitude (3°, MLW, VRef +5, ...) gives a height difference between Pilot's eye path and Wheel path of 10.92m.
If the pilot follows the (lowest) On-Slope angle, the wheels will be at 7.06m above ground when crossing the THLD.
ICAO sets for an aircraft of this size a desired wheel clearance of 9.00m and a minimum of 6.00m.
So at EBCI we are within the acceptable limits although a bit low.
It is also important to check the compatibility between PAPI and ILS signals.
I hope they will obtain the OK without having the need to modify the existing settings.
luchtzak wrote: 12 Apr 2018, 12:03
The flight is planned again for tomorrow morning!
rvsm
Post by rvsm »
An Air Belgium aircraft just departed from EBBR.
rvsm wrote: 13 Apr 2018, 08:49 An Air Belgium aircraft just departed from EBBR.
Shonix
Post by Shonix »
Air Belgium performs touch & go in CRL.
Edit: the plane parked at 9.24am CET on the south Apron.
Shonix wrote: 13 Apr 2018, 09:17 Air Belgium performs touch & go in CRL.
Reason for the touch-and-goes: https://www.aviation24.be/airlines/air-b ... i-airport/
Shonix
Post by Shonix »
luchtzak wrote: 13 Apr 2018, 09:39
Yep, knew it thanks. Just had the chance to see it live :)
simnam
Post by simnam »
Nobody was at EBCI to take some pictures ?
I should've been near the airfield, unfortunatelly I was away today. Too bad :(
Auka
Post by Auka »
I though it'd arrive around 10am :( I'm at 5min of CRL :( I miss it :(
Auka wrote: 13 Apr 2018, 10:20 I though it'd arrive around 10am :( I'm at 5min of CRL :( I miss it :(
I am sorry, but the take-off was scheduled at 09:00 am (recent article about Air Belgium)
simnam wrote: 13 Apr 2018, 10:14 Nobody was at EBCI to take some pictures ?
Bottie, from Aviation24.be, is on-scene and will post later.
asianlao02
Post by asianlao02 »
Apuneger
Post by Apuneger »
Some (unedited) photos of the departure of OO-ABB at Brussels Airport this morning.
Ivan
Facebook | Twitter | Flickr
asianlao02
On the Facebook of Charleroi airport, landing and water canon salute
Amavro
Post by Amavro »
Video of one touch and go at CRL :
Auka
Post by Auka »
A friend that work for the RTBF just told me they were at CRL for the arrival of OO-ABB so this evening at the JT, they'd show more about the arrival of OO-ABB :D
Desert Rat
Post by Desert Rat »
10 years ago the discussion was about LR operation in CRL, now...................
I'm just wondering whether AB will go for the 321neoLR or the 350...😂
All the best Air Belgium!
Fron an ex-SN 😎
Apuneger
Post by Apuneger »
Amavro wrote: 13 Apr 2018, 11:37 Video of one touch and go at CRL
Nice video. Thanks for sharing!
Ivan
