the aircraft was The voyager. The crew were Dick Rutan, Jeana Yeager. & the date of completion December 23, 1986.
Some additional info
The entire 24,986-mile trip had taken 9 days, 3 minutes, and 44 seconds, or a little more than 216 hours.
During their trip, they had averaged around 116 miles per hour (187 kilometers per hour), and when they landed, they only had a few gallons of fuel left.
man u are fast ...
8O
Fossett survived on 12 milkshakes and water during the flight. He said his main problems were headaches, which went away when he drank water, and a lack of sleep. Fossett used bottles as his bathroom.
heres the story http://www.foxnews.com/story/0,2933,149284,00.html
Advisor wrote:MD 11 you are precise. Do you have hidden talent for aviation fuel industry also
I've got my sources...
Here's my question... It's an easy one.
Which "V"-speeds are called out during take-off, in what sequence and what do the speeds stand for?
So I expect three "V"-speeds, the right sequence and their meaning.
TBSC: Szerbousz, you're correct. You're turn now
To be completely accurate: V2 = the minimum safety speed with one engine out
Aerobel.be wrote:De Aviation Leasing Group kocht het toestel vervolgens aan op 6 oktober 1989, waarna het op 24 oktober werd verhuurd aan Buffalo Airways en opnieuw werd ingeschreven in het Amerikaanse register dit maal als N110BV. Buffalo Airways heeft het toestel vervolgens in 1990 doorverhuurd aan diverse maatschappijen als Malev, Aer Lingus, Heavylift en Aer Turas.
In English :
The Aviation Leasing Group bought the aircraft on October 6th, 1989, after which it was leased to Buffalo Airways on October 24th and reregistered in the American register this time as N110BV. Buffalo Airways had in 1990 leased the aircraft to several company's like Malev, Aer Lingus, Heavy Lift and Aer Turas.
