MD-11
Post by MD-11 »
*The coanda effect is the tendency of a stream to stay attached to a convex surface instead of following a straight line in its original direction.
*The Antonov An-72 "coaler"
Andries
Post by Andries »
Correct.
The coanda effect will give the aircraft a larger upwards force, giving the aircraft STOL capabilities.
Your turn again MD-11 !
:twisted: Andries :twisted:
MD-11
Post by MD-11 »
What's the fan diameter of the CF6-80E1 engine ( used in the MD-11 and B744 and other wide-bodies ) , in millimeters?
2896 ?
MD-11
Post by MD-11 »
No :wink:
HorsePower
Post by HorsePower »
Hi MD-11,
Just drop a line to say the B744 is fitted with CF6-80C2B1, not CF6-80E1 :wink: !
Seb.
Andries
Post by Andries »
96 inch diameter :arrow: 2438,4 mm
MD-11
Post by MD-11 »
I'll take that as a sufficient answer.
What a coincidence this engine was at the SNBA opendoors
According to what I found on the web this one is also used on B744s.
Andries
Post by Andries »
I would like to know the nominal tirepressure for the NLG and MLG of a A300B4-203 (like the ones DHL uses). Give me tha answer in PSI (Pound Square Inch)
realplaneshaveprops
Post by realplaneshaveprops »
NLG +/- 160 psi
MLG +/- 180 psi
Koen
Andries
Post by Andries »
At 160PSI NLG, the tirepressue would be to high.
At 180PSI MLG, the tire should be inflated ...
So with some adjustments you could find the correct answer.
realplaneshaveprops
NLG 150 psi
MLG 200 psi
Koen
Andries
Post by Andries »
realplaneshaveprops wrote:NLG 150 psi
MLG 200 psi
Koen
I will take these as correct because they are pretty close to the real ones.
NLG 139-147 PSI
MLG 185-194 PSI
Your turn Koen !
realplaneshaveprops
What is the fuel flow of the LF507-1F of the RJ85/100 (liters plz) in take-off and cruise setting.
Easy for visitors of the SNBA Opendoor!
Greetz
Koen
realplaneshaveprops
Come on, this can't be that hard! Just give it a try
Greetz
Koen
I searched a little bit and didn't found the answer sorry....
realplaneshaveprops
Here are the answers:
Take off: 1200l/h
Cruise: 700 l/h
Avro, can you ask the next question?
Koen
realplaneshaveprops wrote:Here are the answers:
Take off: 1200l/h
Cruise: 700 l/h
Koen
Thanks for the answer.
As for the new question. I don't know why I should ask a new one since I didn't answer. But if you insist ;)
Tell me the function of vertical fences on wings ?
On the follwoing picture you can clearly see two fences on the wing: http://www.airliners.net/open.file/937545/L/
MD-11
Post by MD-11 »
Better aerodynamics? Less drag?
realplaneshaveprops
To reduce the airflow on top of the wing to flow towards the fuselage, and under the wing from flowing towards the wingtip. These airflows create the wingtip-vortex!
Example of a wing fences:
Dassault Falcon 20 http://www.airliners.net/open.file/471161/L
The part of the wing outside the wingfences is the droop leading edge.
Koen
