A little humor
HorsePower
HorsePower
What is the average fuel consumption of a MD-11 during cruise? ( in kgs/hour )
I've changed the question a bit to make it somewhat easier.
Alistairbastian
Not completely ( this is a hint ) correct, but you're close to the answer.
Read the question once more, especially the part between ( ) and then you'll know perhaps what I mean.
Is my question too difficult?
Alistairbastian was getting close.
If the members would like another hint, then ask for it.
But then it becomes perhaps too easy.
This seems quite low to me. I have the figure for the DC10-30: 10,400 litres per hour. MD-11 should be lower than that. Since A1 fuel weighs 0.79 kg/l, it should mean some 8,112 kg/hr for the DC10. Slightly lower for the MD11: ~8,000 kg/hr?Alistairbastian wrote:is it 2462 lb/hr i.e 1116.7 kgs/hr
I have even better data from http://md11.info:
- Fuel consumption at Takeoff: 60,000 lbs. (=27,216 kg) per hour
- Fuel consumption at Cruise: 18,000 lbs. (=8,165 kg) per hour
I'll take this as a correct answer, André.sn26567 wrote: ~8,000 kg/hr?
When we flew to AUA our fuel flow was +/-7500 kgs/hr
This is also what I found here
http://www.finnairgroup.com/group/sijoittaja_1_8_4.html
So it's your turn André
OK, a tough one.MD-11 wrote:So it's your turn André
The registration of German planes is in the format D-xxxx
Which characters (letters or digits) can be used for each of the four x positions? I need four answers, one for each x position.
And an additional question for the highly knowledgeable readers of Luchtzak: the first x position serves to distinguish between different types of aircraft. Please give the type of aircraft corresponding to each character.
- Advisor
sn26567 wrote:OK, a tough one.MD-11 wrote:So it's your turn André
For Example: The 777-247/ADV would mean
777 -> Aircraft Model.
2 -> Model Series.
47-> Customer Code.
ADV -> Advanced or Extended Range or Cargo/Freighter.
A340 -> Aircraft Model.
3 -> Model Series.
1 -> Engine Manufacturer.
3 -> Model Subtype.
X -> Extended Range.
Germany - D-AIGU Lufthansa Airbus A340. So that would mean "GU" on the Lufthansa tail is the fleet number. Also note that in Germany many fleet numbers are simply the last two letters of the registration as in the Lufthansa example.
Now the detailed answer for the benefit of everybody
The rules for registration numbers of aircrafts in Germany have to be divided into 3 time frames:
Pre-1945 - Germany (Deutschland, Deutsches Reich, etc.)
1945 - 1990 - German Republics
1955 - 1990 - West Germany (Bundesrepublik Deutschland)
1952 - 1990 - East Germany (Deutsche Demokratische Republik, DDR)
1952 - 1956 (International Prefix DDR)
1956 - 1981 (International Prefix DM)
1981 - 1990 (International Prefix DDR)
1990 onwards - Germany (Bundesrepublik Deutschland)
This description covers time frames post-W.W.II (West) Germany
1) D (international prefix: D)
2) - (dash, sometimes omitted, usually not)
3) character (0 to 9 or A - C, E - I, K - M, O)
4) character (0 to 9 or A - Z)
5) character (0 to 9 or A - Z)
6) character (0 to 9 or A - Z)
Min.: D-0001 & Max.: D-OZZZ
Explanation
1) International Prefix: D (for Deutschland)
2) Separator: The dash (-) as Seperator of Prefix and Registration is usually displayed.
3-6) Registration: 4 characters, allowed are digits (0 - 9) and letters (A - Z).
The registration can be split into two main categories: numeric: 4 digits (D-0001 to D9999)
for
the block 9500 to 9999 was reserved for some semi-military, government owned, aircraft during the 1960s;
letter: (4 letters D-xAAA - D-xZZZ), where x stands for one of the following aircraft type categories:
A - multi-engine, MTOW >20,000 kg,
B - multi-engine, MTOM >14,000 kg - 20,000 kg,
C - multi-engine, MTOW >5,700 kg - 14,000 kg,
E - single-engine, MTOW <=2,000 kg,
F - single-engine, MTOW >2,000 kg - 5,700 kg,
G - multi-engine, MTOW <=2,000 kg,
H - all rotory-wing, (Hubschrauber = helicopter)
I - multi-engine, MTOW >2,000 kg - 5,700 kg,
K - all powered gliders,
L - all airships, (Luftschiff = airship)
M - all ultra lights, (UL)
O - all manned free balloons,
the categories D, J, N, P - Z are not used (at this time).
Summary: D- plus 4 characters; either 4 digits (for sailplanes/glider) or 4 letters; if letter, the first letter depicts aircraft type category; some military/prototype aircraft were registered in the D-9500 to D-9999 series during the 1960s; no other rules exist, concerning:
special purpose/prototype/evaluation,location.
8) Hope im right!
Aum Sweet Aum.
- Advisor
Thank you for the compliment 8) Andre.sn26567 wrote:Correct, advisor (with a lot of detail). Your turn now!
A leading aircraft manufacturer
Please name the aircraft manufacturer
Please name the aircraft model
Please name the airline
Aum Sweet Aum.
HorsePower
HorsePower
