easyJet in 2015
airazurxtror
Re: easyJet in 2015
17 November 2015 Press Release
EasyJet has signed a firm order for a further 36 A320 Family aircraft taking its cumulative order for the type to 451. The agreement for six A320ceo and 30 A320neo makes easyJet one of the world’s biggest airline customers for the A320ceo Family with 321 ordered and also for the A320neo with 130 on order.
airazurxtror
Re: easyJet in 2015
EasyJet has recorded a record profit in the full year to September 2015. The budget airline told investors on 17 November that pre-tax profit had jumped by 18% from 2014 as a result of low costs.
Full-year revenue rose by 3.5% to £4.69bn (€6.68bn, $7.12bn) while profit fell in the middle of the guidance mark at £686m. Both numbers represent a record for easyJet.
Re: easyJet in 2015
EasyJet is seriously considering the A321, although current delivery dates pushed back until 2018-19.
airazurxtror
Re: easyJet in 2015
http://atwonline.com/finance-data/easyj ... ly+News%29
In September, Lufthansa Group chairman and CEO Carsten Spohr said Eurowings and easyJet could potentially become partners, consolidating the European short-haul market.
However, speaking at the release of easyJet’s full-year results, McCall did not place much emphasis on the discussions.
“This is not top of our list at the moment, but I think you will see more conversations like this because low-cost carriers are driving profitability here in Europe. Low fares will always win on short-haul European routes, so I expect legacy carriers to do more on their efficiency and that the legacy carriers will be talking to all the low-fare airlines,” she said.
airazurxtror
Re: easyJet in 2015
EasyJet has made it possible to track the aircraft of your future flight in advance.
Through a partnership with FlightRadar24, users of easyJet’s iOS app can now trace the plane three hours ahead of their scheduled flight.
For short hop flights your plane could be coming from anywhere. It’s a novelty feature that will surely give some nervous travellers peace of mind, as well as being interesting for aviation fans.
In a practical sense, it would certainly help in times of long delays, which often happen in the winter due to severe weather. You’d be able to spot the plane on the app and know how far off it is from getting to your airport.
http://thenextweb.com/apps/2015/11/30/936361/
- Established02
Re: easyJet in 2015
14/12/2015 MORNING WAVE AT EASYJET
https://www.facebook.com/media/set/?set ... 401&type=3
Re: easyJet in 2015
The kind of incident that occurs from time to time:
Incident: Easyjet A319 at Pisa on Dec 30th 2015, landed on closed runway
An Easyjet Airbus A319-100, registration G-EZBY performing flight U2-1847 from Manchester to Pisa, was cleared to land on Pisa's active runway 04L but touched down on closed runway 04R at 11:11L. The aircraft rolled out without further incident and taxied to the apron.
More on The Aviation Herald; http://avherald.com/h?article=49196d15&opt=0
Picture from FlightRadar24:
Re: easyJet in 2015
Closed RWY??
The NOTAM is poorly written.
RWY 04R-22L is not explicitly declared closed, see below.
quote
B6654/15 NOTAMR B6433/15
Q) LIMM/QMRXX/IV/NBO/A/000/999/4340N01023E005
A) LIRP B) 1512231544 C) 1601312359 EST
E) RUNWAY 04R/22L AVBL AS TWY ONLY.
RUNWAY 04L/22R AVBL AS RWY IN USE.
RMK1:TRAFFIC MAY BE SUBJ DLA
RMK2:DRG TAX OPS MAY BE NECESSARY TO CROSS ACTIVE RUNWAY IN ORDER
TO PREVENT RWY INCURSION FLW STRICTLY ATC INSTRUCTION.REF AIP
AD 2 LIRP 2-1
CREATED: 23 Dec 2015 15:44:00
SOURCE: LIIAYNYX
end quote
Item E (my highlighting) should read : RWY 04R-22L Closed, avbl as TWY only.
The important info is CLOSED and it is missing !
Also methinks RMK2 has higher importance than RMK1 (delay
) and should come first. Also too lengthy text, should start with "Caution, crossing active RWY on Taxi to TKOF ...."
And finally, a temporarily closed RWY must be marked by means of a cross, lighted at night, per ICAO Annex 14.
OK, the crew goofed but there were no safety nets i.e. proper NOTAM and cross on the u/s RWY.
In these circumstances, a human error is possible as no signal (or too poor signal) is there to take you out of the mind-set, i.e. RWY 04R is clearly visible with all its attributes : paint marks, tire marks, possibly lighting, operational ILS, ...
The crew may be used to land at LIRP and it may have been their first landing there since the NOTAM came in force, one week before. And actually it came in force with immediate effect upon issue on 23DEC 15:44 ....
So the runway that you know well is there straight ahead, you've landed there dozens of times before, nothing comes to you to contradict the comfort feeling and all the received signal confirm it is OK. This is the "confirmation bias" as there must be something real big to take you out of the mind set that "everything is OK".
So, "come and see me" for the two pilots for sure but if the ANSV does its job well they should also point out the weaknesses to ENAC and get things straight.
And BTW, they should also check the audio for the info passed by APP. Was it mentioned clearly that 04R was closed? Was the readback correct? If not then a slap on the wrist of the ENAV ATCO. It correctly informed and readback but pilot action differs, then again a confirmation bias issue which is why there are, should be, safety nets.
quote
AD 2 LIRP 2-1
SOURCE: LIIAYNYX
end quote
Re: easyJet in 2015
It seems to me that "available only as TWY " means "closed" for all other uses. But of course if the rules, which I don't know, specify otherwise....
Re: easyJet in 2015
It is indeed necessary to be clear on this type of communication.
And, it seems the airport finally took good note of this. A new NOTAM has been issued, a NOTAMR, in revision of the existing one :
Quote :
/B0015/16 NOTAMR B6654/15
A) LIRP B) 1601030949 C) 1601311000 EST
E) RUNWAY 04R/22L CLSD. AVBL AS TWY ONLY.
RMK 1: TRAFFIC MAY BE SUBJ DLA.
RMK 2: DRG TAX OPS MAY BE NECESSARY TO CROSS ACTIVE RUNWAY IN ORDER
TO PREVENT RWY INCURSION FLW STRICTLY ATC INSTRUCTIONS.
REF AIP AD 2 LIRP 2-1
CREATED: 03 Jan 2016 09:49:00
SOURCE: LIIAYNYX
End quote.
Highlighting is mine.
Better even if they had spelled out the word completely : CLOSED
But OK, it is better. Grazie mille guys.
Hey, wait.
There are other recent NOTAMs for Pisa, including this one of yesterday :
Quote :
B0057/16 NOTAMN
Q) LIMM/QICCT/I/NBO/A/000/999/4340N01023E005
A) LIRP B) 1601120930 C) 1601131530
D) 12 0930-1730 AND 13 0730-1530
E) INSTRUMENT LANDING SYSTEM (ILS) RWY04R ON TEST DO NOT USE FALSE
INDICATIONS POSSIBLE DUE TO FLTCK IN PROGRESS
REF AIP AD 2 LIRP 1-7
CREATED: 05 Jan 2016 13:22:00
SOURCE: LIIAYNYX
End quote.
Why, but why mentioning something that refers to a CLOSED RUNWAY ??!!
Aaarrhhgg
Quote :
SOURCE: LIIAYNYX
End quote.
Hey, wait.
Quote :
B0057/16 NOTAMN
SOURCE: LIIAYNYX
End quote.
Aaarrhhgg
