Where do you get that idea from? Not from Airliners.net again, by any chance?Flanker2 wrote:The opportunity is opening up as LH downgraded their DEN route from daily to twice weekly B744. This is normal as they are reducing many TATL routes, including JFK as part of the restructuring.
http://www.airliners.net/aviation-forum ... 78/#menu27
FWIW - The guy who spread this rumour simply misread the online timetable: DEN stays very much daily and almost all other capacity reductions he thought to have discovered on LH's TATL services, are wrong too...
I've told you before: you often base your ideas on wrong assumptions which you just happen to find online, without ever cross checking them... better try to get hold of factual data first.
For the record: Lufthansa are not "reducing many TATL routes" like you seem to be convinced of based on wrong information, they just happen to cut in their multiple daily FRA-NY route in agreement with the EU in order to let the all important joint venture with UA get final approval from BRU...
BTW- It's exactly this transatlantic JV which you completely fail to take into account in your route proposal, because whatever small advantages DEN might (not) have over any other STAR hub in North America, it is key for a connecting route to make those premium advantages available to as much passengers as possible by having the Euro carrier offering the most connections operate on the route and that carrier definitely is Lufthansa (FRA) by far...
If after that, according to A++ the route ever needs more capacity - which BTW doesn't seem to be the case right now, so clearly DEN isn't such a brilliant place to go to after all then, as you were even convinced LH dropped it to just twice weekly- I can pretty much already earmark which A++ carrier will be next to add DEN to its US network and let me tell you it won't be SN, for sure: think about LX rather....
