crew1990
Post by crew1990 »
This summer S26, there will be 11 A330 in ops.
In S27 there will be 13 A330 in the fleet but the flight planning will be with 12 aircraft only as the 13th will replace the 5 aircaft going in retrofit the one after the other for a period of one year.
In S28 there will be 13 A330 in ops.
I guess the replacement scenario for the A330 will be like for the A319/A320. Meaning the 787/a350 will come from the different plane order within the group. Most probably the first one will come from the order annouced today. But by the time Lufthansa group will keep ordering other aircraft as many long haul aircraft will need to be replaced within the group in the years to come, SN A330 included.
IronBirds@Brussels
Post by IronBirds@Brussels »
In the years to come, yes, the economic pressure becomes significant, not only due to fuel efficiency, but also heavy maintenance cycles and environmental constraints at BRU.
A realistic scenario could be a gradual transition rather than an immediate full replacement.
Lufthansa might start with the oldest A330-300s first (such as SFH, SFJ, SFP), which will be around 26 years old by 2032.
Replacing 3–4 aircraft initially with A350-900s or 787-9 (likely mid-life) would represent roughly 25–30% of the fleet, which is sufficient to properly test a new operating model without committing to a full fleet transition upfront.
By then, the new cabin retrofit introduced in 2026–2027 would already be in place and partially amortized, allowing LH to isolate the impact of fleet modernisation itself rather than product upgrades.
This would give LH group a relatively short but meaningful observation window (around 2032) to evaluate:
- yield improvement on key routes
- performance of higher-frequency, direct operations
- operational efficiency with a mixed fleet
From there, several outcomes seem plausible:
- If performance is weak → fleet could be reduced (~9–10 aircraft)
- If performance is solid but not outstanding → full replacement (~13–14 aircraft)
- If performance is strong → expansion beyond replacement (potentially 16–20 aircraft)
By 2036, even the youngest A330-300 (SFF) will reach around 26 years of age, which effectively sets a hard deadline for completing the transition.
This also raises a key challenge that is often overlooked: pilot training, fleet integration, and transition planning will need to be carefully phased, as the timeline is relatively tight for such a structural change.
Ultimately, one key date to keep in mind is 2028.
By then, the cabin retrofit program will be completed, the long-haul fleet stabilized around its current size, and most of the A320neo deliveries will be in place on the short-haul side.
This should provide LH group with a much clearer picture of SN’s operational and financial performance, making it a logical moment for a formal announcement regarding the long-haul fleet renewal strategy.
At the same time, another structural element will start to come into play: the gradual retirement of the remaining A319 fleet within the following years, which will add further pressure on overall fleet planning.
In that sense, 2028 is likely to be less of a starting point, and more of a decisive checkpoint for SN within the LH Group.
oldblueeyes
Post by oldblueeyes »
Let's try to aggregate some data without any emotions.
Brussels' financial performance is very weak. The company is in fact at black zero profitability and only some sales and lease back wins are ensuring tiny profits ( one can read this in the annual report).
Given these figures, all investments would be likely subject to be in the black figures at year end, unless approved at the HQ.
Four 319 should leave the fleet next year with 5 320NEOS joining the fleet. This would reduce the number of 319 to be replaced to 9, likely over a similar strategy over let's say 4 years (so 2028-31) expected. If so, around 2030'/'31 the short haul fleet would be more than 50% NEOs.
Should additional planes come to the market via bankrupcies etc, i would expect here some opportunities to advance this renewal process.What is the status of the rumored 320NEOs ex Frontier?
On the long haul side, the first step is of course to get the additional two 333 to BRU. The fact that only a part of the fleet should get the new cabin product in a first stage, can indicate either strong financial discipline (as the numbers as shown above are not good) or an open door to start an earlier roll over of the fleet.
What Brussels would get is anyhow already proved into the group , as both 789 and 359 have already real world data. Personally, i would expect a dual startegy and a mixed fleet of pre used and new widebodies.
longwings
Post by longwings »
oldblueeyes wrote: 12 May 2026, 19:39 Should additional planes come to the market via bankrupcies etc, i would expect here some opportunities to advance this renewal process.What is the status of the rumored 320NEOs ex Frontier?
They're somewhat getting lost in the sea of yellow birds, but they are gradually making their way to GYR.
IronBirds@Brussels wrote: 12 May 2026, 17:09 - If performance is strong → expansion beyond replacement (potentially 16–20 aircraft)
Is there room in BRU to accommodate a 20-strong fleet of Brussels Airlines A330s without major infrastructure work? Or would Brussels have to schedule some of them on Middle East or South Asian routes with an evening wave in BRU?
longwings wrote: 14 May 2026, 06:29
It's absolutely possible to accommodate 20 long haul of SN. On condition that they would start with an afternoon/evening wave. And the same for their intra-Europe flights to feed their long haul.
