What is the driver of this NOTAM ?
A3583/18 NOTAMN
Q) EBBU/QPRXX/IV/BO /A /000/999/5054N00429E005
A) EBBR B) 1811120924 C) 1812142359
E)
AN ACFT EXPERIENCING COM FAILURE AND NOT ABLE TO LAND WITHIN THE 30
MIN NORMALLY ALLOWED FOR APCH AND LDG SHALL LEAVE BRUSSELS CTR AND
TMA VIA NW AT 2200 FT AMSL AND LAND AT FIRST SUITABLE AD WITH VMC
CREATED: 12 Nov 2018 09:36:00
SOURCE: EUECYIYN
NORDO ACFT are prohibited anyhow.
What made this NOTAM applicable so suddenly at 09:24z this morning and that ends on 15DEC?
Just curious.
A3583/18 NOTAMN
E)
SOURCE: EUECYIYN
Just curious.
This one:Homo Aeroportus wrote: 12 Nov 2018, 13:57 What made this NOTAM applicable so suddenly at 09:24z this morning and that ends on 15DEC?
A3511/18 NOTAMN
Q) EBBU/QNMAS/IV/BO /AE/000/999/5054N00432E025
A) EBBR B) 1811120700 C) 1812142359
E) BRUSSELS DVOR/DME BUB FREQ 114.600MHZ CH93X U/S
Normal procedure is following 289 radial from BUB VOR, but as this is U/S now, one has to improvise and leave controlled airspace on a NW heading. And they were a bit late in publishing the comloss notam
Thanks info DIBO.DIBO wrote: 12 Nov 2018, 14:35This one:Homo Aeroportus wrote: 12 Nov 2018, 13:57 What made this NOTAM applicable so suddenly at 09:24z this morning and that ends on 15DEC?
A3511/18 NOTAMN
Normal procedure is following 289 radial from BUB VOR, but as this is U/S now, one has to improvise and leave controlled airspace on a NW heading. And they were a bit late in publishing the comloss notam![]()
Good to see the Aviation24 Guard Freq is monitored
I can imagine the Oopsie moment. Did "something" factual triggered it this morning or is it just that the coffee is not so strong?
For those interested in the reprivatisation of TAP (Portugal):
Opinion of the Advocate General of the European Court of Justice:
https://curia.europa.eu/jcms/jcms/p1_1457203/nl/
"Gate closed", but not "gate door is locked and secured"...
This IL-96-300 (RA-96006) didn't operate for 10 years, early November it took off again.
http://batimes.com.ar/news/argentina/ae ... rise.phtml
Aerolineas Argentinas in strike...
"In virtual bankruptcy"...
On 24 November, a drone was reported at 7,000 feet near London Heathrow
Alex Macheras on board Brussels Airlines to Toulouse.
Air traffic control providers to manage Belgian airspace with one single system !
https://press.skeyes.be/air-traffic-con ... gle-system
https://www.aviation24.be/air-traffic-c ... le-system/SR20 wrote: 29 Nov 2018, 17:25 Air traffic control providers to manage Belgian airspace with one single system !
Emirates Boeing 777 go-around after touchdown at a windy Newcastle Airport
A completely unexpected go around was this Emirates 777 A6-EBX arriving from Dubai today at Newcastle Airport.
The wind had been gusting at around 25 to 31kts this Thursday morning. Having established on the approach for runway 25 and been cleared to land by the controller, it looked like a normal approach in the challenging crosswinds from the south.
As the 777 disappeared behind the hedge before touching down, it slammed down onto runway 25, the spoilers deployed, and the next thing full power was applied for a go around.
I've never seen anything like it here at Newcastle Airport. The aircraft then came in for a 2cnd approach and landed safely
Upon landing the aircraft was inspected and initially there was thought to be damage to the rear landing gear. Upon further inspection though it was deemed safe to fly and the aircraft departed Newcastle for Dubai 45 minutes later than planned.
https://www.aviation24.be/airlines/viet ... t-vietnam/
Brand new VietJet Air Airbus A321neo loses both nose gear tires upon landing at Buon Ma Thuot, Vietnam
They probably didn't loose the tyres.
If they look around they may well find them, still attached to the wheels.
Before :
After :
More seriously, it seems something else was lost in the evac : control !
Before :
After :
Should I write: landed so hard that both tires worn of to the rim ?Homo Aeroportus wrote: 30 Nov 2018, 12:13 https://www.aviation24.be/airlines/viet ... t-vietnam/
If they look around they may well find them, still attached to the wheels.![]()
Before :
After :
The evacuation ... I saw that, but the passengers were clearly in distress ... nobody to control the crowd ?
The wheels came off, not the tyres!luchtzak wrote: 30 Nov 2018, 12:37
Right is right! (juist is juist), hence I corrected the article: https://www.aviation24.be/airlines/viet ... t-vietnam/
