Strikes affecting Belgian airports in 2014-2015
Re: Strikes affecting Belgian airports
According to Eurocontrol tomorrow's (1 Sept) Romanian ATC strike has been cancelled.
Lufthansa pilot union Vereinigung Cockpit (VC) has threatened further strikes after negotiations again failed with management over retirement benefits and cost cuts.
The Vereinigung Cockpit pilots union has announced strike action for Lufthansa long-haul flights from/to Germany on Tuesday, 08.09.2015 between 08:00 and 23:59.
Probably no effect on Belgian airports.
What should you do if your are affected? http://www.lufthansa.com/de/en/Travel-Information
And it goes on: another Lufthansa strike. On Wednesday, it covers short-haul and Germanwings.sn26567 wrote:The Vereinigung Cockpit pilots union has announced strike action for Lufthansa long-haul flights from/to Germany on Tuesday, 08.09.2015 between 08:00 and 23:59.
This time, Brussels will be affected!
The Germanwings pilots clearly estimate that the mourning period for the crash of 4U-9525 is over...sn26567 wrote:And it goes on: another Lufthansa strike. On Wednesday, it covers short-haul and Germanwings.
Out of the 20 LH flights to/from BRU, only 2 will be operated to FRA and a single one to MUC
brusselsairlinesfan
No back-up from SN?sn26567 wrote:Out of the 20 LH flights to/from BRU, only 2 will be operated to FRA and a single one to MUC
A ground handling services strike is expected by Menzies Aviation Ibérica staff at Madrid airport. The partial work stoppage will be held on 4th, 11th, 18th and 25th of September from 04h30 to 07h30 and from 19h30 to 21h30.
Out of 3000 daily LH flights, 1000 have been cancelled and 2000 will be operating.sn26567 wrote:Out of the 20 LH flights to/from BRU, only 2 will be operated to FRA and a single one to MUC
Why do you think BRU is proportionally more affected?
airazurxtror
Lufthansa said that, of 180,000 passengers booked for the day, 140,000 could not be carried on their scheduled flights.
The labour tribunal for the western state of Hesse granted the airline a temporary injunction against the pilots union, Vereinigung Cockpit, after hearing an urgent appeal following a lower court ruling in Frankfurt that had OK'd the strike late Tuesday.
The court said it had the impression that the union was seeking to have a say about Lufthansa's low-cost plans, which is not an objective that entitled it to strike under German law.
http://www.dpa-international.com/news/i ... 32211.html
Perhaps because there are more alternatives for stranded passengers on BRU-FRA then for stranded passengers on, let's say, Rome-FRA? There is a good railway connection, even a touringcar transfer is possible, and some business passengers will simply drive to Münich or Frankfurt. It takes more time of course then a flight, but they can drive direct to their final destination in Germany.convair wrote:Why do you think BRU is proportionally more affected?
The court may have stopped the strike, but all the LH flights to/from BRU which were cancelled remain cancelled.airazurxtror wrote:The labour tribunal for the western state of Hesse granted the airline a temporary injunction against the pilots union, Vereinigung Cockpit, after hearing an urgent appeal following a lower court ruling in Frankfurt that had OK'd the strike late Tuesday.
And the two non-cancelled flights from FRA are operated by a small 737-500, whereas the sole MUC flight is on an E195...
And there is one airline taking advantage of the situation:
airazurxtror
What appears to be certain is that there will be no air traffic from Finnish airports between the hours of 11 am and 1 pm on Friday (18th september 2015).
Finnair said that passengers should expect delays that could last into the weekend.
Getting to the airport could be difficult in itself as public transport, including local and long-distance buses, trams and possibly the Helsinki metro will effectively be shut down for the entire day starting at 11 am at latest. Local and long-distance trains will not operate between 6 am and 6 pm.
https://www.aviation24.be/airports/helsink ... on-friday/
European taxi drivers demonstration in Brussels 16 September: leave well ahead of your departure time or take the train to the airport.
Spanish ATC strike tomorrow 4-16UTC. Impact generally expected to be at most moderate.
First announcement by the socialist union: Friday 9th October : railway strike in Belgium.
Railway station Brussels Airport will probably be closed as from Thursday evening 8th October.
The unions are holding a national demonstration in Brussels on Wednesday 7 October as of 11 am. Traffic, including public transport, in and around Brussels may be severely disrupted. Passengers are advised to leave for the airport early to allow for traffic delays.
French National Strike on Thursday. Limited ATC impact currently expected but Eurocontrol hopes to have more information by tomorrow lunchtime.
One of the rail unions called for a 24-hour strike as of 9 pm tonight. As rail services will be severely disrupted, Brussels Airport advises its passengers to come to the airport by bus, car or taxi. However, as the roads to the airport may be very busy, especially during rush hours, passengers should provide ample travel time to the airport.
We would also remind you that work is in progress on the Kiss & Fly area, which may cause further delays. Consider using car parks P1 or P2 which are directly accessible from the A201 access road to the airport.
