realplaneshaveprops
Post by realplaneshaveprops »
Here comes the question:
What is RVSM and what is the purpose of it?
Greetz
Koen
MD-11
Post by MD-11 »
Reduced Vertical Seperation Minima
To keep safe vertical distance between planes and using the airspace as optimal as possible.
Planes with RVSM equipment may fly "closer" to each other.
realplaneshaveprops
That's correct MD-11!
The goal of RVSM is to reduce the vertical separation above flight level (FL) 290 from the current 2000-ft minimum to 1000-ft minimum. This will allow aircraft to safely fly more optimum profiles, gain fuel savings and increase airspace capacity.
http://www.ecacnav.com/rvsm/default.htm
Next question plz?
Koen
MD-11
Post by MD-11 »
In case of "distress" ( for example total engine loss or ditching ) the call "Mayday Mayday Mayday" is made followed by "This is flight****"
What word is called out three times as well in case of "urgency" ( example: lost, partial engine failure ), followed by "This is flight ***" ?
realplaneshaveprops
Pan Pan Pan?
Koen
MD-11
Post by MD-11 »
Correct... :D
realplaneshaveprops
What's so special about the air in aircraft tires? And why is that?
Koen
HorsePower
Post by HorsePower »
Nitrogen, because it's an inert gaz.
realplaneshaveprops
Nitrogen is not a inert gas. So that's not the reason for it's use.
Inert gasses in order of increasing atomic number they are: helium , neon , argon , krypton , xenon , and radon.
Try again.
Koen
HorsePower
I mean it doesn't explode (no oxygen/hydrogen).
realplaneshaveprops
There is a more important reason!
But it's also true that it cannot explode and that their are no chemical reactions at high temperatures because their is no oxygen in the tire.
Koen
HorsePower
Are you talking about oxydation?
MD-11
Post by MD-11 »
The air cannot escape the tyre, so the pressure doesn't drop.
realplaneshaveprops
If you hit the brakes hard on landing, the brakes will be very hot. The temperature in the tyres will rise. If there is enough oxygen in the tyre, it could react with the rubber, it could damage the tyre.
I'm just waiting for the main reason why it's not just normal air!
Koen
HorsePower
MD-11 wrote:The air cannot escape the tyre, so the pressure doesn't drop.
Yeah, I've heard that Nitrogen atomium is a little bit bigger than standard air. Personally, I think it is BS knowing that air is 81% constitued with Nitrogen.
On a side note, have you heard already about inerted tanks (see TWA 800 official inquisity)?
Regards
Seb.
EDIT: Oops :wink:
realplaneshaveprops
I didn't say that, it comes from MD-11.
And yes, I've heard of inerted fueltanks, it's not used in civil aviation I think, only military.
Do you want a extra hint or the correct answer?
Koen
HorsePower
realplaneshaveprops wrote:And yes, I've heard of inerted fueltanks, it's not used in civil aviation I think, only military.
Now, it will be used on civilian aircrafts ($$). I'm not sure but I think all new airplane (A380 + B787) will be fitted with.
realplaneshaveprops wrote:Do you want a extra hint or the correct answer?
I give up, but wait for other members (1 or 2 days) before release the answer.
Regards
Seb.
MD-11
Post by MD-11 »
The air cannot burn
realplaneshaveprops
The other reason I was looking for was that the air needs to be DRY, this is to prevent condensation (and freezing of it) in the aircraft tyre.
So they use Nitrogen because it contains no humid and won't react chemical (like Oxygen).
Koen
realplaneshaveprops
HorsePower,
You gave the best answer, so it's next question comes from you!
Koen
