Re: Abnormalities in BRU-ANR-CRL-LGG-OST in 2014
Squawk Alert 7700 - JAF2660 - TLV-BRU (Technical/Medical Emergency) - B738 - Jetairfly - OO-JAY - Track: http://www.rb24.com/JAF2660
Note: the aircraft made an emergency landing in FRA. Landing now foreseen in BRU at 12:35 today (instead of 00:25 this early morning).
The reason for the landing in FRA was a medical emergency for a pregnant woman.
JAF-607 Brussels-Miami (767-300) took off with a 2 hour delay (09h01 iso 07h00).
Reason: one passenger told a crew member, apparently after an dispute, he had a bomb...
The guy was arrested, his luggage was offloaded and the aircraft was searched by the special police squad. Passengers report that they were informed very well by the crew about what happened.
Source: different online newspapers.
http://www.hln.be/hln/nl/942/Economie/a ... port.dhtml
edited : source added
HQ_BRU_Lover
Post by HQ_BRU_Lover »
A friend of mine flies BRU-JFK on SN501 26/06, what can he expect?
stefanel
Post by stefanel »
Did you just see the Air Canada 833 that departed around 11:45 that still had his gears down above Schaerbeek? It's the first time I see a plane with the gears still down so long after its take-off. I assume there was a problem... anyone knows?
EBAW_flyer
Post by EBAW_flyer »
Not a real problem. It can be that the brakes get a little too hot during a long taxi. They would leave the landing gear down a while in the air to cool them.
stefanel wrote:Did you just see the Air Canada 833 that departed around 11:45 that still had his gears down above Schaerbeek? It's the first time I see a plane with the gears still down so long after its take-off. I assume there was a problem... anyone knows?
According to FlightRadar, C-GHKX (A333) took off normal and is now straight on its way to Montreal.
http://www.flightradar24.com/#ACA833/3b ... 5414891778
TWI-461 Antalya-Brussels (737-400) was expected to land at 15h10
diverted - landed at 14h47 - says BrusselsAirport.be
TU-788 Tunis-Brussels (A320 TS-IML) was on final approach to 25L when the crew went around, reporting an unsafe nose gear.
More details:
http://avherald.com/h?article=476d289f&opt=0
Passenger wrote:TU-788 Tunis-Brussels (A320 TS-IML) was on final approach to 25L when the crew went around, reporting an unsafe nose gear.
More details:
The Aviation Herald forgot another turn around: Egyptair MSR-726 had a bird strike shortly after take-off and returned to BRU around 16:30 this afternoon.
How to screw up your business passengers, part 837:
"go on strike on a Monday morning, without previous warning".
Cityjet / VLM Antwerp is on strike.
Reason : "progress in negociations about salary increase is too slow".
sn26567 wrote:The Aviation Herald forgot another go-around: Egyptair MSR-726 had a bird strike shortly after take-off and returned to BRU around 16:30 this afternoon.
Now they've got it:
Incident: Egypt A320 at Brussels on Jul 4th 2014, bird strike
An Egypt Air Airbus A320-200, registration SU-GCB performing flight MS-726 from Brussels (Belgium) to Cairo (Egypt) with 132 passengers, was climbing out of Brussels' runway 25R when the crew stopped the climb at 2000 feet reporting a bird strike into the right hand engine (V2527) but stating no emergency was being declared, they just needed to return to the airfield. The aircraft landed safely back on runway 25L about 15 minutes after departure.
The flight was cancelled, the passengers were rebooked onto the flight the following day.
One of the fan blades of the engine is reported "completely damaged".
SN2581 OOSSE BRU-TXL is returning back to BRU.
Ryanair Flight FR1012 to CRL is delayed in Warsaw/Modlin for technical reasons.
Zorba
Post by Zorba »
JAI229 Diverted to OST due to weather at BRU
Tot hier en verder
Konus
Post by Konus »
Zorba wrote:JAI229 Diverted to OST due to weather at BRU
All other aircraft land normally, even JAI227. Maybe shortage of fuel or technical ?
Zorba
Post by Zorba »
Nope, problem is the ceiling (BKN001). They need more apparently.
Tot hier en verder
Zorba wrote:Nope, problem is the ceiling (BKN001). They need more apparently.
Regional tv (Focus WTV):
- detour to OST indeed because of fog. Company rule to divert early (see above post from Zorba)
- passengers were not allowed to deboard because some of them had no visa for Belgium
- passengers complained: "no info, no water. Only around noon we received half a glass of water and... a waffle"
- crew went into overtime, causing another delay
http://www.focus-wtv.be/nieuws/passagie ... g-oostende
Looking at FR24 playback, it looks like JAI229 made 2 attempts to land at BRU before diverting to OST.
Bel33
Post by Bel33 »
OODJP in route to Geneva was diverted to Bru this evening (SN 2723)
Anyone knows why?
http://www.flightradar24.com/data/fligh ... 3/#3c83f4b
EBAW_flyer
01:30LT, heavy thunderstorms around BRU and LGG. JAF4218 NBE-BRU go-around just before the CB, 8 aircraft for LGG in the holding overhead Charleroi, 2 overhead DIK and to top it all, ABX28S STN-LGG just declared emergency because he lost some navigation systems.
