nordikcam wrote: 28 Aug 2019, 19:16
At least the flight is not canceled but at 19:15 the plane is still in Brussels ... probably with only cargo !
Just left 2 minutes after your post.
Seems they will short cut ACC and go straight to LFW, stopping at ACC for crew change before heading back to BRU.
What happens when, once in a while, an SN flight to AFI got delayed "a bit"?
Normally parked at a T Gate. But BRU cannot keep so many gates behind the "T border" for so many hours. What if a Pax arrives after the border has been opened and boards the delayed flight?
I noted that SN277 today, and I seem to remember a previous one as well, was parked at the B Pier. B34 today for SN277.
Is that intentional to avoid the problem of T gates being blocked?
That would be a tell-tale sign for the seasoned traveler. Flight leaves from B Pier = delay.
What could have been the reason for the delay today? Tech? Documents?
I guess the crew checked in this morning so comes a moment you run short of hours and need to call in a Stby.
