Re: Abnormalities in BRU-ANR-CRL-LGG-OST in 2018
convair wrote: 10 Jan 2018, 11:57 Apparently, SN247 return was cancelled last night. OO-SFO AOG in Freetown? Any news?
"...A Brussels Airlines A330-300 performing flight SN-247 from Freetown (Sierra Leone) to Brussels (Belgium), was accelerating for takeoff from Freetown when the left hand engine surged prompting the crew to reject takeoff. The aircraft slowed safely and returned to the apron..."
Source - more info:
http://avherald.com/h?article=4b3e35ac&opt=0
For the passengers of Sunday's delayed flight Ryanair FR-2986 Valencia-Brussels VLC-BRU: you are entitled to the indemnity as per EU-Rule 261/2004: Ryanair decided to use "your aircraft" to do a Valencia-Santiago-Valencia, when the aircraft had to leave for Brussels: FR-2985 Brussels-Valencia arrived on time indeed (arr at 12h45, ETA was 13h10).
https://www.flightradar24.com/data/aircraft/ei-dpp
Passenger wrote: 22 Jan 2018, 00:06 For the passengers of Sunday's delayed flight Ryanair FR-2986 Valencia-Brussels VLC-BRU: you are entitled to the indemnity as per EU-Rule 261/2004: Ryanair decided to use "your aircraft" to do a Valencia-Santiago-Valencia, when the aircraft had to leave for Brussels: FR-2985 Brussels-Valencia arrived on time indeed (arr at 12h45, ETA was 13h10).
For the passengers of Wednesday's delayed flight FR-2926 Lisbon-Brussels LIS-BRU, arrival in Brussels with 4,5 hours delay (ETA 13h50, actual arrival 18h21): you are entitled to the indemnity as per EU-Rule 261/2004: Ryanair decided to use "your aircraft" to do a Lisbon-Faro-Lisbon, when the aircraft had to leave from Lisbon to Brussels: FR-2925 Brussels-Lisbon arrived at LIS with just 34 minutes delay.
https://www.flightradar24.com/data/aircraft/ei-dhs
Passenger wrote: 19 Jan 2018, 00:49
rwandan-flyer wrote: 19 Jan 2018, 00:33 The RwandAir flight to Kigali has been canceled yesterday (18Jan17). The RwandAir A330 is currently at Brussels. Do you know what happened ? Thanks
Aircraft arrived with 20 minutes delay from LGW (London), so it looks indeed like AOG at BRU:
https://www.flightradar24.com/data/aircraft/9xr-wp
can those passengers claim indemnity as well?
nordikcam wrote: 11 Jan 2018, 20:56
Darjeeling wrote: 10 Jan 2018, 22:01 SFM was stuck with fuel leak in OUA
SFO stuck in FNA indeed...
can they claim indemnity?
just thinking that of the mods allow these type of posts it should be done for every delay and cancellation out of a Belgian airport and not just one carrier?
sean1982 wrote: 24 Jan 2018, 22:05... it should be done for every delay and cancellation out of a Belgian airport and not just one carrier?
And what stops you from doing just that??
Incident from Monday 29th Jan 2018:
"... A Croatia Airlines A319-100 performing flight OU-4456 from Zagreb (Croatia) to Brussels (Belgium), departed Zagreb's runway 23 and was climbing through FL310 already in Austrian Airspace when the crew decided to return to Zagreb due to a bird strike..."
More info:
http://avherald.com/h?article=4b44cce8&opt=0
Airbus330lover
Post by Airbus330lover »
Flight SN2288 (OO-SSJ) stuck in OSL....
After landing yesterday evening I saw a United 777 parked on Apron 3, about stand 314, rather unexpected sight at 20:30 local.
Checking on FR24 it seems this N782UA went AOG after flying the UA950 from IAD yesterday and is still a sitting duck at 11:00 this morning.
No big deal - but I just heared there was a computer problem at Swissport BRU this afternoon, causing delays for luggage handling.
Wohowbagger
Post by Wohowbagger »
GPS callibration for EBBR?
Some kind of land survey seems more likely.
Wohowbagger
KriVa wrote: 06 Feb 2018, 09:38 Some kind of land survey seems more likely.
Well given there was a second Cessna (OO-GPS) and it was 23:30 and dark outside...
They don’t always perform surveys in the visible light spectrum, though. OO-GPS often performs survey flights, not only GPS calibration flights.
SR20
Post by SR20 »
Thermography probably. Last month the very same aircraft performed that kind of mission overhead Liège.
https://www.rtbf.be/info/regions/liege/ ... id=9810897
Snowfall expected on Friday: allow for traffic disruptions – flight delays are possible. Brussels Airport winter operations teams will make every effort to reduce the impact on the airport to a minimum.
More info: https://t.co/DhQfZVkeap
Av24.be
Post by Av24.be »
Snow is expected at Brussels Airport this afternoon, https://www.aviation24.be/airports/bruss ... -february/
KLM cancelled a number of flights, yesterday evening Brussels AIrlines decided to cancel 7 flights that were scheduled this afternoon (Venice, Gothenburg, Birmingham, Milan, Basel, Vienna and Hanover). Kim Daenen told newspaper Sudinfo that all passengers on these flights have been informed and rescheduled.
Treeper wrote: 05 Feb 2018, 23:32 GPS callibration for EBBR?
or perhaps related to this?
https://www.vrt.be/vrtnws/nl/2018/02/09 ... luchtfoto/
OO-SFX AOG in Douala?
