Brussels Airlines OO-SFM to Ougadougou holding above Belgium
Finally: descending.
Airbus330lover
Post by Airbus330lover »
4 hours ...... very long time for the PAX
OO-SFM now landing 25R, over OM at 15:50.
More than 4 hours after take off, .. from 25L.
All is well that ends well.
ryandaughter wrote: 17 Apr 2017, 15:25 Still holding for now. I noticed that OO-SFU has been carried from hangar to the airport...maybe to be prepared to take over SN255 once OO-SFM is back to BRU...we ll see what happen.
Yes...next departure for flight 255 at 7PM...today !
nordikcam wrote: 17 Apr 2017, 16:07
Why so late? They've had 4 hours to prepare the replacement aircraft!
Good that SFM is safely back though.
Airbus330lover wrote: 17 Apr 2017, 15:44 4 hours ...... very long time for the PAX
I hope they were served their lunch. ;)
Homo Aeroportus wrote: 17 Apr 2017, 15:53 OO-SFM now landing 25R, over OM at 15:50.
...from 7R ! ;)
Come on H.A. ! You !? :o
convair wrote: 17 Apr 2017, 16:27
...from 7R ! ;)
Ouch, good pick Convair.
I'm ashamed. :oops:
Using the reciprocal QFU, how can I do such a mistake !?
But I seem to remember that when I wrote this I was young and had drunk.
Apuneger
Post by Apuneger »
Facebook | Twitter | Flickr
SN501
Post by SN501 »
convair wrote: 17 Apr 2017, 16:17
The potential replacement aircraft landed this morning at BRU. It is likely under maintenance at the moment. The replacement aircraft could be SFM itself then.
SN501 wrote: 17 Apr 2017, 16:58
OO-SFU took off a few minutes ago. As said above, it's been waiting on the apron or at a gate since 3:25 pm.
So, again, what took so long?
Bel33
Post by Bel33 »
Call back a new crew
Transfer cargo
Put out all luggages from SFM- control -
Prepare the plane (catering...), obtain all authorizations and plan the flight...
For long haul, it take easely 3-4 hours!
SN501
Post by SN501 »
convair wrote: 17 Apr 2017, 19:59
Maybe SFU wasn't ready for a quicker departure as this bird was the back up aircraft of the day. In that context, preventive maintenance was maybe ongoing and couldn't be interupted earlier.
Also, the crew of SFM was probably time out for a new departure in SFU. Find a complete back up crew is not that easy.
And there are many other possibilities that can explain why it has been done this way. Operational management is an art. :)
Luke777
Post by Luke777 »
I am too late to listen...nobody of the enthousiasts here has an airband scanner ? At the company freq you would have been able to listen to the cause in stead of guessing...
SN501 wrote: 17 Apr 2017, 20:28
Thanks, SN501. Layman questions. :roll:
Luke777 wrote: 17 Apr 2017, 20:31 I am too late to listen...nobody of the enthousiast here has an airband scanner ? At the company freq you would have been able to listen to the cause in stead of guessing...
I have one, and use it occasionally (legally!). But what is the company frequency?
Don't pilots communicate with their ops offices via ACARS, these days, rather than over VHF?
Luke777
Re: Brussels Airlines OO-SFM to Ougadougou holding above Belgium
Post by Luke777 »
131.950 - no acars, at such close distance VHF voice is the most easy way of comm, even when transatlantic most pilots still prefer good old HF in stead of CPDLC wich is not reliable at all times. At longhaul flights, technical issues are discussed over satcom, most SN330 s have satcom telephone in cockpit enabling communications with ops.
Hehe, thanks!
RTM
Post by RTM »
Only read this thread now. So too late to give any current comments on the situation, so just for info since the issue was raised.
The fuel dumping capabilities of an A330...
For the A333 it is no option. Just simply not installed. It does have the dummy dumping pipe coming out of one of the flaptrack fairings either side, but it is just closed at the back. As for the A332, it is an option you could have installed. Though not mandatory. But its extra fuel capacity can make it more attractive to dump rather than to burn off fuel. Having said that though, none of the SN A332 are fitted with the system.
Duke
Post by Duke »
RTM wrote: 18 Apr 2017, 14:10 The fuel dumping capabilities of an A330...
Do you mean no option for the A333 of Brussels Airlines, or for every A333 ?
Duke
