Difference between Boeing, MD and Airbus winglets?
Sorry misunderstood your question
Personally I don't see why they couldn't do that. In fact they even fly sometimes with one winglet instead of two
But I don't think that it's economicaly viable to take them off for a short period (one week). Yes you could maybe save a little bit in maintenance costs and in fuel, BUT to remove them and to attach them again you would need to pull the plane off its schedule for quite a few hours. And as you know it's very expensive to keep a plane on the ground, even for a few hours.
Just my 2 cents though.
bigjulie
Winglets most of the time don't go up at an angle of 90° with respect to the wing. Look at the A330 or A340 winglets. Now when the angle is smaller then 90° the span of your plane will automatically increase by a factor of cos(a)*l (of l is the length of the winglet and a the angle).bigjulie wrote: :shakehead: I can not see how having winglets effects the 80m box; winglets go up straight, or at a bit of an angle, they don't increase the actual outward wing length.
Jense
No I wasn't, sacha. And maybe it's better to read the whole topic before posting this quote.sacha wrote:are you joking, jense?Jense wrote:The winglets on the 744 don't spare any fuel, they're only used for
a) advert
b) design
EDIT: and if this wasn't clear enough, time has come to quote myself:
Jense wrote:@ Avro
Sorry mate, I was wrong. It's the MD-11 who uses more with winglets than without.
(I was mixing them up, appologises
Does most of this go into wing reinforcement? Some time ago I saw the 'winglet guy', who attaches the winglets to the 747. Those winglets are really light, the guy could easily lift one with one hand. No way a winglet would weigh 240 pounds almost all by itself.Avro wrote:teddybAIR,
To give you and idea, the added weight on the B737 by installing the winglets is 480 pounds.
I don't know the exact weight for bigger planes.
One winglet of a B737 weighs 132 pounds (~ 60 kg)earthman wrote:Does most of this go into wing reinforcement? Some time ago I saw the 'winglet guy', who attaches the winglets to the 747. Those winglets are really light, the guy could easily lift one with one hand. No way a winglet would weigh 240 pounds almost all by itself.Avro wrote:teddybAIR,
now the 480 pounds are for the entire plane which means 240 per wing -> This again means that the attachment mechanism weighs 108 pounds.
Those are only approximate values I don't know the real ones.
And yes AFAIK the winglets are made of composite materials.
