TUI fly Belgium in 2017
Re: TUI fly Belgium in 2017
TUI Belgium removes planned St. Maarten service in W17
TUI Belgium in recent schedule update has removed planned St. Maarten schedule, previously scheduled to commence on 30OCT17. The airline originally planned 1 weekly Brussels – St. Maarten – Punta Cana – Brussels triangle routing, on board Boeing 787-8.
The airline’s Punta Cana service remains unchanged at 3 weekly level. Previously filed St. Maarten schedule as follow.
Code: Select all
TB151 BRU1005 – 1350SXM1505 – 1620  PUJ 788 1
TB152 SXM1505 – 1620PUJ1750 – 0720+1BRU 788 1
Source: Airline Route
Sai
Post by Sai »
As a further step in the alignment between TUI fly Belgium & TUI fly Netherlands, the latter will upgrade its long-haul on board service up to the standards of its Belgian counterpart.
From October 12 on, meals, drinks and IFE are included on TUI fly Netherlands long-haul flights, previously just 1 meal and a glass of water were included, IFE had to be paid for.
source: tui.nl
Happy to see they chose to upgrade the lesser one and didn't choose to downgrade the service of TUB...
However I wonder if they can resist the pressure of the emerging low-cost long-haul (e.g Joon, Norwegian,...etc) where you have to pay for everything.
An EuroAtlantic B767-300ER (reg CS-TKS) is doing TB-217 Brussels-Orlando-Miami-Brussels. Apparently with a delay (unforeseen backup) and with another schedule problem in Orlando (crew rest?).
CS-TKS:
https://www.flightradar24.com/data/aircraft/cs-tks
TB-217:
https://www.flightradar24.com/data/flights/tb217
Maybe because OO-JNL (TUI's own 767-300ER) is AOG?
OO-JNL:
https://www.flightradar24.com/data/aircraft/oo-jnl
TUI fly will open 3 new routes, according to Travel Express Benelux Facebook page...
Antwerp - Firenze as from June 18
Brussels - Aruba as from June 15 (Mondays, with SDQ)
Brussels - Curacao as from June 18 (Fridays, with SDQ)
The flights from Brussels will be operated with 787s, so conforming the info at the begin of this year with a 787 that could replace OO-JNL during the next year.
Maybe a new E190 for TUI ?
TLspotting wrote: 24 Oct 2017, 19:45 TUI fly will open 3 new routes, according to Travel Express Benelux Facebook page...
Couldn't hesitate to write about this news 8-) https://www.aviation24.be/airlines/tui-f ... m-antwerp/
Matthias
Post by Matthias »
According to planespotters.net, the first 737MAX for Tui will have OO-MAX as registration.
Has somebody more info about the frame? Is it already in the FAL? What will be the configuration? Whew will it come to Belgium?
Matthias
Bralo20
Post by Bralo20 »
MSN: 44588
L/N: 6735
Engines: CFMI LEAP-1B
But no info found on the status.
It's not yet mentioned in the production list found on https://docs.google.com/spreadsheets/d/ ... 2050202365
Matthias wrote: 13 Nov 2017, 15:35 According to planespotters.net, the first 737MAX for Tui will have OO-MAX as registration.
Again TUIfly has no pattern whatsoever for its registrations. They should take example on Brussels Airlines where the registration clearly says the type of aircraft.
Bralo20
Post by Bralo20 »
sn26567 wrote: 13 Nov 2017, 17:57
They have a pattern (not exactly by type but by company)...
It used to be:
Jetairfly = OO-Jxx
But unfortunately Jetair has to be erased and thus are current and future registrations:
TUI Airlines Belgium = OO-Txx
Seems that the first MAX will get a special registration though...
Bralo20
Post by Bralo20 »
TUI Belgium isn't the only company without any pattern, their main supplier Boeing has also strange numbers but there it's with the serial numbers of the planes. The only consistency with Boeing are the line numbers, the serial numbers however... For example In a batch of sequential line numbers (6690-6695) they have MSN's: 60880 (MAX8) -> 31277 (800NG) -> 63620 (800NG) -> 61201 (800NG) -> 40845 (800NG) -> 61208 (MAX8)...
Guess it's sometimes easier to take the hard road :mrgreen:
Bralo20 wrote: 13 Nov 2017, 21:32
It used to be:
Jetairfly = OO-Jxx
Indeed, and initially, it was even OO-JAx (with the exception of JBG in honour of Gerard Brackx).
Then came the Dreamliner which appropriately got a JDL registration.
Then came the Embraers which appropriately got JEB and JEM. But oops, the 3rd one was JVA... And oops again, JEF was not an Embraer. And what did JOS look like?
Now they start all over with OO-Txx, but without a clear pattern.
DeltaWiskey
Post by DeltaWiskey »
737MAX wrote: 14 Nov 2017, 19:26 And you say Brussels Airlines uses registrations that clearly says the type of aircraft...? :roll:
I am not really getting the point of this discussion, but regs for Brussels Airlines are as follows:
A320: OO-SN...
A319: OO-SS...
A330: OO-SF...
Past:
RJ100: OO-DW...
RJ85: OO-DJ...
PttU
Post by PttU »
Why should there be any logic?
I understand it's satisfying for our autistic sides, but besides that?
PttU wrote: 14 Nov 2017, 20:16 Why should there be any logic?
Very classy comment!
I guess that, a.o., this registration pattern makes internal and operations communications a bit easier. And they are not all autists (with all due respect to the people who are!).
flightlover
Post by flightlover »
convair wrote: 14 Nov 2017, 20:43
It's indeed easy for a supplier to know what type of plane they are catering for.
It also helps when a lot of similar planes are present to make a basic selection just by knowing the differences between different types in case of last minute bay changes. Although that is for the more experienced workers :)
JAFflyer
Post by JAFflyer »
While all should be very enthusiastic about a brand new airplane type operating for a Belgian airline (yes, still OO-...), we start discussing registrations... If this would have been a brand new aircraft type for Brussels Airlines (unlikely for many years to come, as only second hand aircraft are good enough...), nobody would complain about a registration and this thread would have had +10 pages of people being ecstatic...
Factory new, a brand new aircraft type, B737MAX is coming to Belgium, an not only 1...and I'm not even talking about a second 787 Dreamliner. Can we be a little more optimistic about that?
Yuqu12
Post by Yuqu12 »
If I'm not wrong: the 2nd Dreamliner will be another 787-8 from another airline in the TUI-group and the new 787-9 will then go to this other airline, not TUI Belgium.
DeltaWiskey
JAFflyer wrote: 15 Nov 2017, 08:36 While all should be very enthusiastic about a brand new airplane type operating for a Belgian airline (yes, still OO-...), we start discussing registrations... If this would have been a brand new aircraft type for Brussels Airlines (unlikely for many years to come, as only second hand aircraft are good enough...), nobody would complain about a registration and this thread would have had +10 pages of people being ecstatic...
I am very happy for TUI that they will be getting a new aircraft / type, factory new. I also think it is quite a nice "gesture" to give this bird a special registration. :) (I just don't really get the whole discussion on this forum about the registrations, but that's a different matter)
A new aircraft / type isn't unlikely for Brussels Airlines for many years to come, it could be as soon as spring 2019. :twisted:
crew1990
Post by crew1990 »
DeltaWiskey wrote: 15 Nov 2017, 09:25 A new aircraft / type isn't unlikely for Brussels Airlines for many years to come, it could be as soon as spring 2019. :twisted:
A321neo LR I guess?
JAFflyer
Post by JAFflyer »
Yuqu12 wrote: 15 Nov 2017, 09:22 If I'm not wrong: the 2nd Dreamliner will be another 787-8 from another airline in the TUI-group and the new 787-9 will then go to this other airline, not TUI Belgium.
I didn't say the 787-8 will be factory new, it will indeed come from TOM as soon as they receive their 787-9. That being said, the oldest 787-8 in the TOM fleet is only 4 years old, still relatively new and far more advanced than the A330's or A340's...
I was just trying to point out the double standards. Everything about Brussels Airlines is wow, even second hand A330's from LH, but with TUI, people start discussing about registrations. Something that has bothered me for quite some time now on this forum.
And just to be clear, I would applaud a new aircraft type at Brussels Airlines!
