Re: Abnormalities in BRU-ANR-CRL-LGG-OST in 2018
Anyway, SN203 is back in the air towards DKR. So it must have been a medical. Maybe Lyon was the only hospital able to cure the illness of that passenger?
Saturday's TUI TB-623 returned to BRU half an hour after take off, causing also a huge delay for the return flight TB-624 from Miami too:
https://www.flightradar24.com/data/airc ... l#11090248
A TUI UK's A332 (G-VYGM) came to rescue:
https://www.flightradar24.com/data/flights/tb623
https://www.flightradar24.com/data/aircraft/g-vygm
Passenger wrote: 16 Apr 2018, 09:29 Saturday's TUI TB-623 returned to BRU half an hour after take off, causing also a huge delay for the return flight TB-624 from Miami too:
Indeed. I published the story last night at 01:00 ;) https://www.aviation24.be/airlines/tui-f ... -saturday/
The TUI UK A332 is in fact operated by AirTanker.
sn26567 wrote: 16 Apr 2018, 09:42
TB-624 is enroute: ETA Miami-Brussels at BRU is 01h54 this night:
https://www.flightradar24.com/JAF624/110f0b80
20th April: it seems that TAY-071X Turku-Liège diverted to Stockholm Arlanda.
EI-STK = 737-400F
https://www.flightradar24.com/data/airc ... k#111b67ad
Kalitta CKS244 operating BAH-BRU on behalf of DHL has always been taking the shorter route over Turkey. Since a few weeks CKS244 has been obliged to take a considerably longer route over Egypt. Kalitta seems to have a traffic rights issue with Turkey, possibly due to geopolitical tensions between Turkey and the USA.
Vic Diesel
Post by Vic Diesel »
Yesterday (22.04.2018) flight DL80 ATL-BRU started squawking 7700 some 20 minutes before landing in BRU. There was quite a number of fire engines and other vehicles rushing around 25L with sirens and blue lights flashing and also a helicopter hovering around the Belgocontrol area. After the plane (B763 reg. N1200K) landed on 25L, a 4x4 drove along the rwy. Meanwhile, the aircraft vacated rwy 25L on C5, continued briefly on OUTER-10, came to a halt and subsequently turned around using E3 and E1, eventually coming to full stop in front of the Satellite.
Does someone know what caused the emergency?
Viktor
Monday's outgoing TUI TB-1937 from Brussels to Funchal was unable to land there: OO-TMA (737 MAX 8) went into holding near Funchal, but diverted to Faro.
On Tuesday morning, OO-TMA did (another) attempt to get from Faro to Funchal. After quite some holdings, they've landed:
https://www.flightradar24.com/data/aircraft/oo-tma
domtom
Post by domtom »
The Ethiopian 787 was starting its left bank over Brussels (EU neighborhood) after T/o from 25R, with the gear still down. That's really weird. Anyone knows why?
domtom wrote: 24 Apr 2018, 22:52 The Ethiopian 787 was starting its left bank over Brussels (EU neighborhood) after T/o from 25R, with the gear still down. That's really weird. Anyone knows why?
Apparently a normal flight to Vienna:
https://www.flightradar24.com/data/flig ... 5#1126cc2e
...and from Vienna to Addis Ababa:
https://www.flightradar24.com/ETH725/11272669
One brake deactived? Procedure as per minimum equipment list: gear remains down till the wheels stop spinning.
HQ_BRU_Lover
Post by HQ_BRU_Lover »
Could be a possible case (I think some months ago the same happened to another aircraft @ BRU, if I'm not mistaken it was an EK 777), another one might be overheating?
Desert Rat
Post by Desert Rat »
Brake overheat after TO?
Overheated Brakes after T/O would be unusual, slightly hot brakes after T/O could certainly happen, though.
weather starts hindering ops @BRU, large weather avoidance deviations on approach, 2 consecutive go arounds,...
JVSpotter
Post by JVSpotter »
DIBO wrote: 29 Apr 2018, 21:37 weather starts hindering ops @BRU, large weather avoidance deviations on approach, 2 consecutive go arounds,...
EIN63J diverting to EHBK
EIN63J back in BRU after the short hop from MST.
VO147 ANR-Zurich limited birdstrike on take off, returned to land.
Today's TUI TB-2873 Brussels-Faro was operated by OO-JEM (ERJ-190):
https://www.flightradar24.com/data/flights/tb2873
Return flight TUI TB-2874 Faro-Brussels will be done by OO-JEB (also ERJ-190).
ETA TB-2874 was 20h05, but is now announced as delayed 03h20:
https://www.flightradar24.com/data/flights/tb2874
Thus: OO-JEM seems to be AOG at Faro, with most probably OO-JEB sent over with engineers - and to bring the passengers back home.
https://www.flightradar24.com/data/aircraft/oo-jeb
