Are there long-haul flights at BRU ?
Abnormalities at BRU / ANR / LGG / CRL / OST 2011
Re: Abnormalities at BRU / ANR / LGG / CRL / OST 2011
It is due to the weather at AMS ? What's happening ?
Was due to severe fog at AMS this morning.
The only long haul that diverted to BRU was SinCargo B74F 9V-SFO.
Cheers - Gerald
Cheers - Gerald
Thanks for the info
- Established02
What is the normal procedure for an aborted landing on RWY 25R?
XM7197 to LIN took off from 25R at 16h15. At that time FQ5609 from TFS was (expectedly) on finals for 25R. I did not have a visual overview, but I understand something caused FQ5609 to abort the landing procedure and to opt for a go-around.
I would have expected that a go-around on 25R would require a righthand turn heading for Mechelen.
However the FQ A320 was surprisingly turning to the left side overflying the airport building, crossing the 25L axis and turning back over Sterrebeek. In the meantime I expect the XM airbus may have been instructed to maintain the runway heading longer than usual.
I wanted to check the situation on http://casperflights.com/ but they no longer show the history beyond 2 hours, at least not for free.
The standard missed approach procedure for 25R is as follows:
Climb to 2000'. When passing 700' turn RIGHT onto HDG 020 to intercept and follow R-251 inbound to BUN VOR. On this radial continue climb to 3000'. No right turn before OP/OM. Report to ATC as soon as practivable.
However, ATC can of course deviate from this and instruct pilots to fly another procedure e.g. for sequencing or spacing.
- Established02
Thanks sdbelgium. The HDG here was rather 200. As you indicated, the FQ A320 was possibly instructed to follow the missed approach procedure for 25L due to other interfering traffic north of 25R.sdbelgium wrote:When passing 700' turn RIGHT onto HDG 020 to intercept and follow R-251 inbound to BUN VOR. On this radial continue climb to 3000'. No right turn before OP/OM. Report to ATC as soon as practivable.[/b]
Look on flightradar24.com and zoom to Brussels.
Click on "live" right above. Select 2011-11-18 and 15:10 UTC and click on Star playback. You will see that the flight to Milan continue in the runway heading
- Established02
Thanks, Mathieu.Mathieu wrote:Look on flightradar24.com and zoom to Brussels.
The Alitalia is EI-IXF and the Thomas Cook is OO-TCN. Only OO-DJX north of 25R.
OO-TCN probably turned to the left because there was OO-DJX north of the airport
@ the moment problems with de SQC7973: http://planefinder.net/flight/SQC7973 / http://planefinder.net/flight/SQC7973
The Dutch weather bureau has sent out another severe fog warning for Sunday morning (20th Nov).SabenaForever wrote:I think BRU is becoming AMS!!
I noticed a lot of diversions to BRU from AMS!
I think a could count untill know 10 diversions, and more are coming:
- 3 KLM 737-800
- 2 KLM 737-700
- 1 Air Arabia Maroc A320
- 1 Finnair A320
- 1 Ukraine Int Airlines 737-400
- 1 El Al 737-800
- 2 EasyJet A319
- 2 KLM cityhopper F100
- 1 Malev 737-600
- 1 CSA A320
Indeed. There was a problem with one bleed air pressure regulation valve:-KoeKe- wrote:@ the moment problems with the SQC7973: http://planefinder.net/flight/SQC7973
http://avherald.com/h?article=4465e38c&opt=0
And also for tomorrow Monday 21st.Passenger wrote:The Dutch weather bureau has sent out another severe fog warning for Sunday morning (20th Nov).
Confirmed:
But a good deal of fog here in the South, too:TAF EHAM 201639Z 2018/2124 VRB03KT 0500 FG BKN002 OVC003 PROB40 2018/2109 0250 OVC001 PROB30 2109/2116 04006KT 1500 BR BCFG BKN003 BKN005 PROB30 2116/2124 0250 BKN001=
TAF EBBR 201700Z 2018/2124 06003KT 6000 NSC BECMG 2018/2020 2500 BR BECMG 2020/2022 0500 FG TEMPO 2022/2124 0100 OVC001=
Just for clarification, the issue was actually not a BLEED problem . The aircraft had a outflow valve malfunction and the remaining valve could not sustain pressurization - both in AUTO and MAN modes - effectively , hence the air turnback. The need for fuel jettison was minimal since the aircraft burned quite a lot while holding for troubleshooting.Passenger wrote:Indeed. There was a problem with one bleed air pressure regulation valve:-KoeKe- wrote:@ the moment problems with the SQC7973: http://planefinder.net/flight/SQC7973
Source: a comment in The Aviation Herald
I live between Antwerp airport and Antwerp city, and fog is worsening here.
- Established02
At 13h06LT OO-DHW had a missed approach on 25R, possibly because of not being able to maintain the minimum distance with OO-DJT.
SN2626 Hamburg-Brussels rerouted to LGG.
SN3736 Malaga-Brussels rerouted to CRL.
According to www.schiphol.nl AF5366 from Nantes to Amsterdam should be sitting at BRU (aircraft should be F-GRGM and ERJ135).
Monday's AT832 Casablanca-Brussels (763) had a technical problem just after take off. Aircraft returned to Casablanca and pax were switched to another 763, bringing them in Brussels with a delay of just 3 hours.
more details, registrations, etc: Aviation Herald
http://avherald.com/h?article=446840db&opt=0
