Re: Diversions from around the globe (medical, technical, ...) 2020
Edelweiss flight #WK24 to Cancun (Airbus A340-300 reg. HB-JMG) had to dump fuel before returning to Zurich - reason unknown for now.
Malaysia Airlines flight #MH319 to Kuala Lumpur (Airbus A330-300 reg. 9M-MTG) was forced to return to Beijing due to cabin pressure issue.
TK45 CPT-IST (A330-300 ref. TC-JNI) is currently diverting to Johannesburg due to the not retracted nose gear, after it burned some fuel for approx 90 minutes above the Atlantic Ocean.
https://www.aviation24.be/airlines/turk ... ding-gear/
lucas
Post by lucas »
TAP A330 NEO performing Lisbon (LIS) to New York (JFK) just landed at Lajes Airfield (TER) in the Azores after diversion. Reason unknown. The aircraft was almost three hours into flight when it turned towards TER.
https://www.flightradar24.com/TAP209Z/2363c7b1
lucas
Post by lucas »
D4-CCG, a B757 of Cabo Verde Airlines flying from Espargos (SID) to Washington (IAD) diverted to Santa Maria (SMA) in the Azores.
https://www.flightradar24.com/TCV692/23661489
Edit: The aircraft is again on its way to Washington, so it was probably a medical diversion.
pele
Post by pele »
Flight AFR21QB(Embraer E170STD) has been diverted to Brussels, what was the emergency?
kazansky137
Post by kazansky137 »
pele wrote: 08 Jan 2020, 08:51 Flight AFR21QB(Embraer E170STD) has been diverted to Brussels, what was the emergency?
Probably medical as the plane (F-HBXF) left BRU at 09h48. Emergency was declared at 08h18 ; plane landed around 08h37.
/AKN
Kapitein
Post by Kapitein »
EJU7942 TFS - AMS will come to BRU.
Late departure in TFS, so they didn't get in before the AMS curfew.
Kapitein wrote: 18 Jan 2020, 22:15 EJU7942 TFS - AMS will come to BRU.
And then? Bus to Amsterdam or night in Brussels before continuing in the air?
The easyJet aircraft is an A320 registered OE-IJG. I find it strange that it is diverting to BRU as this is not a U2 base.
Kapitein
Post by Kapitein »
sn26567 wrote: 18 Jan 2020, 23:18
Indeed bussed to AMS.
Probably because BRU is the best option in this case. Going to the UK doesn't help the pax much and other based are maybe also to far.
At lot of planned diversions and flight cancellations at ALC (Alicante).
TUI fly flight TB1101 ANR-ALC just departed to VLC - Valencia.
Alicante-Elche Airport will be closed from 1:00 p.m. today to 1:00 p.m. tomorrow due to the effects that the storm Gloria could have on the areas affected by the fire last week.
All flights from/to Keflavik Airport are currently cancelled. Wind gusts up to 57kt
Lufthansa flight #LH460 from Munich to Miami (Airbus A380 reg. D-AIMG) turning back toward Europe squawking 7700. Reason for return currently unknown.
sn26567 wrote: 23 Jan 2020, 15:13 Lufthansa flight #LH460 from Munich to Miami (Airbus A380 reg. D-AIMG) turning back toward Europe squawking 7700. Reason for return currently unknown.
cargo smoke indication, heating device smoking
http://avherald.com/h?article=4d25951c&opt=2048
luchtzak wrote: 24 Jan 2020, 14:23
Soneil
Post by Soneil »
TUI OO-JAS on LIL-RAK diverted to AGP for unknown reasons
AC837 MAD-YYZ had to turn back to MAD due to a part of tire into an engine.
easyJet flight U2 8485 from Geneva to London Gatwick (A320 reg. G-EZTH) is currently diverting to Paris CDG. Reason unknown. UPDATE: medical emergency.
airBaltic flight BT677 from Riga to Malaga (A220-300 reg. YL-AAU) is making a U-turn just before reaching the Spanish border.
