Airport Worker Killed by Exploding Tire
ALM
Post by ALM »
Posted on Tue, Feb. 24, 2004
Associated Press
TOLEDO, Ohio - A jetway tire exploded while being repaired, killing a maintenance worker at Toledo Express Airport.
Brian Bergeon, 34, had removed the tire from a jetway, which is used by passengers to walk from the terminal onto an airplane. He apparently was standing on the tire and trying to remove it from the rim when it exploded Monday, authorities said.
The rim struck him in the head.
The cause of the accident was under investigation.
Avro
Post by Avro »
What a terrible accident :cry: :cry: :cry:
Jense
Post by Jense »
Avro wrote:What a terrible accident :cry: :cry: :cry:
Indeed :cry:
Bad news again... :cry: :(
greettzzz
Lame
Post by Lame »
I know this was on a jetway, not an Aircraft.
However the same principle should be followed.
When changing a wheel assembly on an Aircraft, you are supposed to deflate the tyre before removing the wheel from the axle, most Engineers don't, but you are supposed to for this reason. :cry:
