country registration code "OO" ?
Something I always have wanted to know, but only now I can reach people who might know it :
The country registration codes for civil a/c can be 'logical' (eg F for France, D for Deutschland, I for Italia, etc), or ‘not so logical’ (eg OO for Belgium, PH for the Netherlands, N for USA, etc), or even be an alpha-numeric combination (eg 3B for Mauritius).
Does anyone know the origin of these codes (eg Chicago Convention 1947 ? ICAO ? IATA ?) and the ‘meaning’ behind some of these codes, especially the origin of the Belgian OO-code ?
Geert
Geert
Frm memory, it seems that country codes started in 1920. At that time, they were of the type x-xxxx. For Belgium, it was O-Bxxx. There were only a handful of countries which had aeroplanes, hence one initial letter seemed to be enough.
Why O? Well I guess that the initial B was already attributed. To China? I am not sure. The B after the O- seems obvious for Belgium.
In 1929, most registrations changed from x-xxxx to xx-xxx. Since Belgium had already an initial O, this was maintained and a second O was added. The change was minimal for existing planes. Ex: O-BOEL became OO-OEL
One should also remember that the airplanes of the Belgian army (and I mean the land forces, not the Air force) are registered OL-xxx, xxx being one letter and two numbers. Example: the Alouette helicopters: OL-A01. The Puma of the federal police (formerly gendarmerie): OL-G01.
OT was reserved for the Belgian Air Force.
Well, this is all regulated by the ITU (www.itu.int)
It has everything to do with the radio onboard the aircraft.
The radio callsign is used to identify a radio station (fixed, mobile, airmobile, maritime, ...) and it's origin.
The ITU publishes a table of prefixes alocated to every country.
The country is responsible for the distribution of the callsigns to the
different users/services. (for Belgium: BIPT, for the US: FAA)
some examples of the prefix blocks allocated to countries:
ON-OT Belgium
PA-PI Netherlands
W,K,AA-AL United States
G,M,2 United Kingdom
depending on the usage the format of the callsign can change:
OO-ABC = aircraft = 3 letters after prefix
ON5LL = amateur station = 1 digit and at least 2 chars after prefix
OT3L = amateur high power station = 1 digit (year) and 1 letter after prefix
OST = Oostende radio = shortwave broadcast station = 1 letter after prefix
it's difficult to find a complete list of prefixes and usage but this one is not bad:
http://daveg4otu.tripod.com/pref.html
some of you probably don't know, but for every radio station/signal you need a permit ...
is it for radio, tv, radar, broadcast, digital, ...
hope this clears up things..
Filip
ON1AFN
ON-OT Belgium
PA-PI Netherlands
Filip
ON1AFN
Coved for the armed Forces
These codes aren't only used with the Land Forces, also the Navy uses similar codes... e.g. Alouette III M1 is OT-ZPA. The same with the Former Sikorsky's from the 40th SQN.
Greetz
TOM 8)
Greetz
TOM 8)
http://www.fototbr.be [Freelance press photographer]
