Jet airways veered off runway at Goa --> airport closed
An incident for Jet Airways today...
- Attachments
- S61227-043213(1).jpg (681.77 KiB) Viewed 1688 times
- quixoticguide
Re: Jet airways veered off runway at Goa --> airport closed
Strange place to veered off the runway
Jet Airways release:
The story on The Aviation Herald: https://avherald.com/h?article=4a2a6d90&opt=0
A Jet Airways Boeing 737-800, registration VT-JBG performing flight 9W-2374 from Goa to Mumbai (India) with 154 passengers and 7 crew, backtracked runway 26, lined up runway 26 and was accelerating the engines for takeoff when the aircraft continued to turn right, the crew rejected takeoff, the aircraft went off the right runway edge almost perpendicular, went over soft ground and across a road and came to a stop with the nose gear collapsed and both engines making ground contact.
The airline reported due to a technical glitch the aircraft spun nearly 360 degrees while aligning the runway for takeoff !!!
this is quite unusual. thank God everyone is safe
You haven't seen a tree until you've seen its shadow from the sky.
http://flyinganarchy.com/
- quixoticguide
thank god the airplane went over to the soft ground and no any major causalities happened. otherwise it could be a disaster.sn26567 wrote:The story on The Aviation Herald: https://avherald.com/h?article=4a2a6d90&opt=0
By the way, welcome to Luchtzak, Cody12Cody12 wrote: thank god the airplane went over to the soft ground and no any major causalities happened. otherwise it could be a disaster.
- quixoticguide
There was also another incident at Delhi airport yesterday morning.
https://www.aviation24.be/forums/viewtopic ... 18#p344218
