BRU Winter 2017-18: news, new routes, airlines
BRU Summer 2018
BRU Winter 2017-2018
BRU Summer 2017
BRU Winter 2016-2017
BRU Summer 2016
BRU Winter 2015-2016
BRU Summer 2015
BRU Winter 2014-2015
BRU Winter 2013-2014
BRU Winter 2012-2013
BRU Winter 2011-2012
BRU Summer 2011
BRU Winter 2010-2011
BRU Summer 2010
BRU Winter 2009-2010
BRU Summer 2009
BRU Winter 2008-2009
BRU Winter 2007-2008
BRU Summer 2017
BRU Summer 2016
BRU Summer 2015
BRU Summer 2011
BRU Summer 2010
BRU Summer 2009
Re: BRU Winter 2017-18: news, new routes, airlines
I've seen in the Delta Air Lines booking engine that the Atlanta flight is still bookable in december 2017. Possible that it will be a year round flight instead of a seasonal flight?
AA has definitly left BRU ? Winter and Summer ?
It used to be year round, it was temporary cancelled because of the attacks, so I guess they'll go back to their old schedule.
AA left some years ago, only the former US (now AA) route with PHL remained but it seams that they gave that up also. Don't think it was a decent route, it used to be a 767 operated route but in the end it was only a 757 route.
I don't think we'll see AA back soon, the NYC area is covered by UA/SN/DL and the same applies for the ORD area with the UA flight. Maybe we'll see the 2nd planned UA flight to EWR again, which was cancelled before it started due the attacks. Time will tell.
I think BRU-MIA would do very well for AA. They have a huge hub there and can connect the South, the entire Caribbean, Central & South America... not to mention the Florida traffic.
The same applies for UA from Houston... So it would rather be a *A-flight between BRU and IAH if connecting pax are enough to warrant the flight.JustPlanes wrote: ↑28 Jan 2017, 06:15 I think BRU-MIA would do very well for AA. They have a huge hub there and can connect the South, the entire Caribbean, Central & South America... not to mention the Florida traffic.
Icelandair likely to place the B737 MAX on routes from Reykjavik to Billund, Bergen, Geneva, Halifax, Minneapolis and Newark once aircraft begins delivering in first half of 2018, following by Helsinki, Hamburg, Brussels, Birmingham, Montreal and Philadelphia in the winter.
New route: Brussels - Sion (Switzerland) offered by a new airline!
https://www.ft.com/content/fbca8b62-f52 ... 4e55513608
Thanks for the information, Traveler, and welcome to Luchtzak!
Welcome! Announced on luchtzak:Traveler wrote: ↑24 Feb 2017, 22:59 New route: Brussels - Sion (Switzerland) offered by a new airline!
https://www.aviation24.be/airlines/sports- ... nter-2017/
The problem is that transiting through the US is a huge PITA due to the continuing lack absence of international transit (i.e. some passengers would need a visa, you need at least an ESTA authorization). None of this bureaucracy is necessary if you transit through a normal, modern hub.JustPlanes wrote: ↑28 Jan 2017, 06:15 I think BRU-MIA would do very well for AA. They have a huge hub there and can connect the South, the entire Caribbean, Central & South America... not to mention the Florida traffic.
AA would need to be a lot cheaper to compensate for this.
Will be less of an issue when the border screening gets done in Brussels as that will be a much shorter queuegumblebee wrote: ↑25 Feb 2017, 07:54The problem is that transiting through the US is a huge PITA due to the continuing lack absence of international transit (i.e. some passengers would need a visa, you need at least an ESTA authorization). None of this bureaucracy is necessary if you transit through a normal, modern hub.JustPlanes wrote: ↑28 Jan 2017, 06:15 I think BRU-MIA would do very well for AA. They have a huge hub there and can connect the South, the entire Caribbean, Central & South America... not to mention the Florida traffic.
But anyway you need to pick up your luggage and recheck them, still not easy...flightlover wrote: ↑25 Feb 2017, 09:40Will be less of an issue when the border screening gets done in Brussels as that will be a much shorter queuegumblebee wrote: ↑25 Feb 2017, 07:54The problem is that transiting through the US is a huge PITA due to the continuing lack absence of international transit (i.e. some passengers would need a visa, you need at least an ESTA authorization). None of this bureaucracy is necessary if you transit through a normal, modern hub.JustPlanes wrote: ↑28 Jan 2017, 06:15 I think BRU-MIA would do very well for AA. They have a huge hub there and can connect the South, the entire Caribbean, Central & South America... not to mention the Florida traffic.
Is it the same if you transit true Canada?
Don't count on that happening as long as The Orange One is in charge in the US.flightlover wrote: ↑25 Feb 2017, 09:40
Mind you. A trial of preclearance in Brussels is much closer than you think.teach wrote: ↑25 Feb 2017, 10:43Don't count on that happening as long as The Orange One is in charge in the US.flightlover wrote: ↑25 Feb 2017, 09:40
"A trial", are you sure about that? There are more than a dozen US preclearance locations and none ever had a trial before final implementation. Also preclearance requires changes to infrastructure, is that worth it for just a trial?
Every airport has its own approach towards such a project and each time the concept of US preclearence is evolving. Also mind that "a trial" is quite a generic word in this context, it can still mean a lot of things in practice.
Delta change their Atlanta – Brussels Service. It converts to year-round again, but with 4 weekly 767 flights, instead of planned daily.
Source: Airlineroute
Are the 4 flights a week not for the winter season. The summer season is still daily no?
