Cargolux lands on a van parked on the runway
What: Cargolux Boeing 747-400 freighter en route from Barcelona, to Luxembourg
Where: Luxembourg
When: Jan 21st 2010
Why: While landing in low visibility due to foggy conditions, the Cargolux 747’s tires went through the roof of a maintenance truck whose crew was working on the runway ground lighting. The van’s driver was not hurt; the van was damaged by being landed on by the 747 (no doubt!), and the Boeing’s tires were damaged after going through the van’s roof. No one, however, was hurt, although the maintenance person was hospitalized for shock.
Where: Luxembourg
When: Jan 21st 2010
Re: Cargolux lands on a van parked on the runway
Courtesy : The Aviation Herald (who also has a photo of the van):TCAS_climb wrote:What: Cargolux Boeing 747-400 freighter en route from Barcelona, to Luxembourg
Where: Luxembourg
When: Jan 21st 2010
http://avherald.com/h?article=42620150
YIKES!
Theres nothing better than slow cooked fall off the bone BBQ, Texas style
I must say that the van is in much better shape than I expected.
well, we have these 2 youtube films:
http://www.youtube.com/watch?v=_TVFgR0G ... re=related
and
http://www.youtube.com/watch?v=rELFSGei3hE
and
Does the pilot who landed on the caravan still have his pilot licence ? I just couldn't believe it if the FAA didn't dump his certificate into the paper shredder.
This was a CAT (2) approach!!! Everybody is on alert then! RVR 350 meters , that means FOG! The 747 was cleared to land.... And YOU blame the pilot???? Shame on you!TCAS_climb wrote:Does the pilot who landed on the caravan still have his pilot licence ? I just couldn't believe it if the FAA didn't dump his certificate into the paper shredder.
You are quite right andorra-airport, but the fog is irrelevant. Either the B747 was not cleared to land, and then the blame is on the PIC, or there was a landing clearance issued while a vehicle was on the runway, this is to be blamed on local authorities, either tower operator or ground controller. Surely we will learn eventually from the official investigation?andorra-airport wrote:This was a CAT (2) approach!!! Everybody is on alert then! RVR 350 meters , that means FOG! The 747 was cleared to land.... And YOU blame the pilot???? Shame on you!TCAS_climb wrote:Does the pilot who landed on the caravan still have his pilot licence ? I just couldn't believe it if the FAA didn't dump his certificate into the paper shredder.
FWIW it IS frightsome, the same could have happened to me on a much smaller scale recently: on final in an ULM at a non-disclosed EB-aerodrome I was much disturbed to see a 4x4 parked in the middle of the runway. Turned out to be a mole-chaser... Luckily I was in better visibility so could decide to go around well in time.
Ah! These B747 pilots, they do have trained subtility! Which is a good thing on ILS landings, meseemeth.earthman wrote:I must say that the van is in much better shape than I expected.
Settle down, folks. I was refering to the taildragger who intentionally lands on a moving caravan in the second video posted by Regi...
right, my fault again. It seems that I have taken over the role of NCB quite well
About that plane on the camper, how are they going to get it off again?
Well, I suppose exactly the same way it landed on it. Just zoom along the runway until you reach liftoff speed. The tricky part must be the application of power by the taildragger.
Or a less chivalrous way: with a crane...
