I have a question about the flighttimes in fs. When I'm doing EDDF - EBBR, it takes me about 30 minutes to get there. But the real time timetable says that it should take a little less than an hour to fly the route.
Can it be that I'm flying to fast? FL was 220, speed below FL100 was 250 and above was 309.
Thanks,
Lamal
Problems with realistic flighttimes
- Skyfighter
a departure time is the actual time that you should start pushback
So if you departure hour is 1400Z than you should start push at 1400Z
an arrival time is the actual time that you should arrive at the gate
So if you're arrival hour is 1500Z than you should be at the gate at 1500Z
But don't mind if the time isn't correct,the flight you did is about 30 minutes starting from airborne until touchdown.
The time in the table is to let people know they should be on time
greets
greets
